big block vs small block
Old 10-13-2002, 01:08 AM
road2xs
road2xs's Avatar
Default big block vs small block
are there any benefits of a small block vs a big block? if so what are they?
Old 10-13-2002, 01:15 AM
Tedardo
Tedardo's Avatar
Default Re: big block vs small block (road2xs)
I can only think of maybe one. Miles to the gallon is a little better for the SB. Parts are cheaper and usually a little easier to find for a small block. But from what I've heard, big blocks are the most fun :chevy
Old 10-13-2002, 03:12 AM
Zack Wenning
Zack Wenning's Avatar
Small blocks are also much lighter than big blocks, which generally means a more balanced, better handling car. Small Blocks are also much easier to work on in the engine compartment. There are acceptions to this but, small blocks can be made to rev to higher rpms than big blocks.
Old 10-13-2002, 03:30 AM
'79ProwlerOrange
'79ProwlerOrange's Avatar
Default Re: big block vs small block (Zack Wenning)
you would have to be more specific. an aluminum BB is about the same weight as an iron small block. all i could think is that they are cheaper to build and parts are easy to find.
Old 10-13-2002, 10:02 AM
Gordonm
Gordonm's Avatar
Default Re: big block vs small block ('79ProwlerOrange)
HEAT. The big blocks tend to hold heat in the compartment more than small blocks. I think it is because of the lesser amount of room with the big block. Why not go with a large small block say 427 ci in or so. Of course a 540 big block is pretty :cool: also
Old 10-13-2002, 06:22 PM
bence13_33
bence13_33's Avatar
Zack:
For the most part you are correct. But I have had my 454 to 7200 RPMs before without missing a beat. With a correctly built big block you can still turn the RPMs. Heck a solidly built 427 can turn upwards of 8,000RPMs. But that's also the benefit of a big block, you don't need to rev them as high. :)
P.S. I still love small blocks, my buddy has a really nice 327 in his S10....it revs so smooth.
Old 10-13-2002, 09:12 PM
BlueL36
BlueL36's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
BB. You will run out of courage before you run out of throttle.
Old 10-13-2002, 09:25 PM
467-Ratman
467-Ratman's Avatar
I would say if you have a strong heart, go with the Big Block! If on the other hand you are easily scared by things stick with the small block. My car was a small block last year and I made the switch to a BB this past winter. I am still in awe of the power and no matter what anyone says about their small blocks reving to 7000rpms, the way a rat motor runs will blow you away!! No offense to my small block friends because its still a great motor but............. No substitute for cubes!!! :chevy
Old 10-13-2002, 09:34 PM
vettedreams
vettedreams's Avatar
Default Re: big block vs small block (467-Ratman)
GO BIG BLOCK is all I can tell you! I"ve never owned a BB till just recentlly, wow is all I can say, and I"ve had some mean small blocks, and the combination of a 4 speed with the BB awesome!!!!!!!!!!!!!!!!
Old 10-13-2002, 09:35 PM
Markm10431
Omega Aficianado
Support Corvetteforum!
Markm10431's Avatar
St. Jude Donor '08-'09,'13, '14
I don't mean to hijack the thread or anything but DAMN zak.. think your sig pic is big enough?
To big block vs small block
Quick Reply: big block vs small block
