How hard to replace the rear window in a '69 convertible top?
Re: How hard to replace the rear window in a '69 convertible top? (rbasting)
you can't, only way to replace the rear window is to replace the whole top. The plastic window is sown in place.
Re: How hard to replace the rear window in a '69 convertible top? (Wrencher)
The original tops had a "heat sealed" rear windows. They were not sewn in. If yours is sewn, it's been replaced already, OR you don't have a "factory correct style" top. For all the PIA to remove the top to replace the window, you might as well put a new top on it. :) Chuck
Re: How hard to replace the rear window in a '69 convertible top? (Chuck Gongloff)
The original tops had a "heat sealed" rear windows. They were not sewn in. Chuck
