Determine how much 1.6 rockers change cam duration
Old 12-11-2002, 01:19 PM
Tominator
Tominator's Avatar
Default Determine how much 1.6 rockers change cam duration
I am curios how having 1.6 roller tip rockers has changed my duraration and lift.
I have a 222@50 with .470 lift cam and best I can figure from reading different articles is with the 1.6 rockers my cam is more like 230@50 with .500 lift
Do these numbers seem right? :confused:
Old 12-11-2002, 01:31 PM
gkull
gkull's Avatar
Received 1,327 Likes on 1,057 Posts
Default Re: Determine how much 1.6 rockers change cam duration (Tominator)
All the books indicate @ 2 degrees more at the .050. They have proved it with a dial indicator and a crank degree wheel. It's not that much of a change Less than 1% The lift is where the gains generally come from. Because the valve is flowing more CFM by being higher off the seat during it's whole lift cycle.
[Modified by gkull, 12:32 PM 12/11/2002]
Old 12-11-2002, 01:33 PM
yellow 72
yellow 72's Avatar
St. Jude Donor '09
Multiply rocker ratio X lobe lift to get lift at valve. Duration change is minimal :cheers:
.470 with 1.5 = .502 with 1.6. Duration not enough to worry about.
[Modified by yellow 72, 2:35 PM 12/11/2002]
[Modified by yellow 72, 2:36 PM 12/11/2002]
Old 12-11-2002, 09:15 PM
Tominator
Tominator's Avatar
Default Re: Determine how much 1.6 rockers change cam duration (yellow 72)
GKULL; so for duration I would be around 224 if I'm understanding you right
yellow 72; just curious how you come up with the .470 with 1.5 = .502, I tried multiplying and dividing but my answers look weird.
[Modified by Tominator, 8:15 PM 12/11/2002]
Old 12-11-2002, 09:30 PM
mp77
mp77's Avatar
I think he means 1.5 is the stock rocker and your cam is.470 lift. Increasing the rocker to 1.6 equals more lift giving you .502 lift with the same cam.
Old 12-11-2002, 10:56 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
I don't know if this answers your question or not or if it is even right, but it was posted by Aaron74 a few months back. A while back I posted basically the same question and a formula was posted that I seem to remember being similar if not the same. I can't find the posts in searching recent or archived topics.
For example, my lift is .460 (lift with standard 1.52 rockers) / 1.52 = .302 (cam lift) .302 X 1.6 = .484. (your lift with 1.6 rockers)
In the case of my ZZ4 cam, with a dual pattern it looks like the cam with 1.6 ratio rockers, would have
.474/1.52=.312*1.60=.499 and .510/1.52=.336 * 1.60=.537
so .474/.510 with 1.52 rockers would be .510/.537 with 1.60
Your cam with .470 lift (single pattern?) would be as follows.
.470/1.52=.309*1.6=.495
On the duration increase I remember reading an article in a car mag a while back that had the formulas in it too, they seemed to back up what gkull stated that actual duration would only increase a very small amount.
Old 12-12-2002, 01:33 PM
Tominator
Tominator's Avatar
Default Re: Determine how much 1.6 rockers change cam duration (Smokehouse69)
So the cam is 222@50 and .470 lift (single pattern) with 1.5 rockers and with 1.6 it increases to 224@50 and .495. This is the info I was looking for.
Guys thank for all your effort. :cheers:
[Modified by Tominator, 12:35 PM 12/12/2002]
To Determine how much 1.6 rockers change cam duration
Quick Reply: Determine how much 1.6 rockers change cam duration
