[SBC ALUM HEADS] Is this a good deal???
Location: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
They're on EBAY http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
I'm building a 383 and I'm looking for 23 degree - 64cc heads, what do you think???
Re: [SBC ALUM HEADS] Is this a good deal??? (69shark)
Yes, these are good heads and a lot of people use them. The price isn't too spectacular as you can get them at Summit Racing for $969.95.
Here is the link: http://store.summitracing.com/partdetail.asp?part=20742
Plus, these only cost $7 to ship through Summit, and you can rest easy knowing customer service will be there if you need it. :yesnod:
It is also important to match the springs to the cam you are running. What type is it, and what are its specs, part number?
:cheers:
[Modified by VETDRMS, 8:31 PM 3/31/2003]
[Modified by VETDRMS, 8:32 PM 3/31/2003]
:cheers:
Cruise-In I Veteran
Re: [SBC ALUM HEADS] Is this a good deal??? (VETDRMS)
:cheers:
:cool: :cool:
I wouldn't purchase a set of heads without knowing or at least having some idea of what cam you are going to run. It could cost you more in the end. Also, you want to match your components as much as possible. If you are going to be using a roller cam or mech. flat tappet you will most likley need a different spring setup on those heads. What power range are you looking for? Intake/Carb/exhaust you plan on running? These are all important when choosing a particular set of heads.
Think of it as solving an equation with more than one unknown variable.. :lol:
There are a lot of people who really know there stuff roaming the forums, I'd be happy to help you out on choosing a good combo for your needs. :chevy
Re: [SBC ALUM HEADS] Is this a good deal??? (dman535)
Don't you need to buy special rockers, pushrods etc for these heads ?
:cheers:
Cruise-In I Veteran
At this point of the build up all I need is the 23 degree and 64cc chamber on aluminium heads, as the shop that is doing the machine work and I will be making these decisions as needed. So far we have 4 bolt block, Eagle 383 stroker kit, Edelbrock performer intake, Dynomax ceramic coated headers. We will be deciding on cam and valve train after I get the heads. I'm also looking at some aluminium head from a company called Proline from Australia , their Lighting model.
Here is the link for a good supplier of Dart heads, best prices I could find and shipping is cheap.
http://www.sdpc2000.com/cart.asp?act...d=741&pid=7554
