DUAL QUADS ON A 454 HELP
I am putting my 454 back in my 1972 I want to put the dual carb setup I have on the car but I want to keep it under the stock BB hood. Is this possible?? Thanks!
:steering:
:steering:
Re: DUAL QUADS ON A 454 HELP (Love My 72 and 77)
I think so. I have seen a 71-454 with the 2x4's using the Edelbrock intake and the stock BB hood for a 454. Look in the paper catalog or online at http://www.edelbrock.com at the heights of the 2x4 manifold and compare measurements front and back to the stock. This is using the Edelbrock AFB's.
I had to use the L-88 hood on my C-3....and it's still CLOSE -1/4 inch or so!
:yesnod: :chevy :chevy :yesnod:
But the 2x4 setup is THE ***** for the street!
Re: DUAL QUADS ON A 454 HELP (MassVette)
From the looks point of view the dual carbs look trick but from a functional point of view a single carb is better. It is 1/2 the trouble to tune, to jet, to buy in the first place and a single carb can put out just as much hp.
With that said :)
I run a pair of 850 double pumpers.
[Modified by norvalwilhelm, 1:13 PM 4/10/2003]
With that said :)
I am putting my 454 back in my 1972 I want to put the dual carb setup I have on the car but I want to keep it under the stock BB hood. Is this possible?? Thanks!:steering:
I love my 77 & 72 also!!!!
Eddie
:seeya You will have to go with an L-88 or other Cowl Induction style hood! :yesnod: But I'm running a Edelbrock Street Tunnel Ram... and you'll be running the low profile 2-4 set-up!
[Modified by Intimidator454, 7:44 PM 4/10/2003]
