Crossfire to Non-Crossfire?
What would it take to convert crossfire to non-crossfire? Any computer mods or just carb mods. Want to buy 81 but looking at an 82 and have not heard good things about crossfire system.
Re: Crossfire to Non-Crossfire? (Skyhigh)
Shyhigh, what are your 'plans' for the C3? Is is strictly for daily driving? Many highway miles? Make a 'Stop-Light Bandit' out of it? If the '82 you're looking at is in good working order, and you don't mind it running high-15/low-16 second ETs, leave the CF alone. I've put 7,000+ miles on mine in three summers; not many, granted, but I've had NO problems what-so-ever, AND I get 23+ MPG @ 75 MPH! I'm in contact with other CF-owners, who tell me that some mods (exhaust, gear-swap) can make these run low-15/high 14 second ETs. You can investigate the Cross-Fire Vault for even more technical info. One young man runs in the 11s @ 119+ MPH (that is Z06-style times, my friend!) with gears, exhaust, and a healthy dose of N2O. Don't dis-regard the CF right away; it may be for you! :chevy :chevy :chevy
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Crossfire to Non-Crossfire? (Glensgages)
Cross fires run fine, they just got a bad rap.
If you want to convert to non-computer control:
Replace intake manifold, carb, distributor.
You may also need a way to have the transmission do lock-up in fourth gear, and then you can ditch the computer as well. Kit's for lock-up range from $75 -$250 depending on features.
If you get rid of the distributor, let me know. I need a computer controled HEI distributor.
CI 6-7-8 Veteran
DesertDawg ran a 15.13 in a stock (bone stock) '82 Collectors edition.
With a smaller person, some race gas, good exhaust system, rear gear swap - you could be in 14.7 range.
Re: Crossfire to Non-Crossfire? (BSeery)
1 Post
St. Jude Donor '09
Yes the crossfire is a good setup, it starts every for me. and I have had zero problems with it. They are not screamers, more civilized than the older vettes but still fun.
If you get the 82, and still want to yank the crossfire, I will take the manifold and throttle bodiesoff your hands, like Bseery said you only need a few parts to change it out.
And welcome to the Corvette Forum. :seeya
1 Post
St. Jude Donor '09
Re: Crossfire to Non-Crossfire? (Twin_Turbo)
You're not planning on going faster are you? Addicted to the strip?
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I don't have crossfire, but I'd like to have one. I think the benefits of fuel injection are considerable. I'd gladly give up some performance for the lack of hassle and improved fuel economy.
1 Post
St. Jude Donor '09
I've got a couple of them crossfire systems lying around... if only shipping wasn't as expensive I'd be rid of that poopie already :)
the shipping would be more than the parts are worth. :lol:
Re: Crossfire to Non-Crossfire? (Desertdawg)
Well... if shipping is via a 4-6 week method it's pretty reasonable. I've had a huge radiator (31X17X6) shipped for about 50$
[Modified by Twin_Turbo, 6:35 AM 4/19/2003]
I still use my 82 as my daily driver...running without problems for over a year now,with very decent fuel economy.
Not the fastest Vette around,but very good for daily use!
CI 6-7-8 Veteran
Re: Crossfire to Non-Crossfire? (Pete Z)
The shipping on two exhaust manifolds (not nearly as big or heavy as a fully loaded intake manifold) from AZ to England ran $118.00
CI 6-7-8 Veteran
hmm.. that was not 4-6 weeks USPS was it?
Find out the weight of a complete intake, and dimensions giving 4"s all the way around for packing material and you can get an estimate on shipping.
1 Post
St. Jude Donor '09
SO Marck, if shipping is not very much. How much do you want for your intake and throttle bodies? Together or seperate.....
don't have TB's... sold my last set some time ago. Might want to check over on the crossfire vault. Also, maybe Ken73 has an intake, I think he has a few and will even do the work on them.
