Spark Plug Gap after intake/cam/headers upgrade?
Do I have to change the spark plug gap after installing new Performer intake, 260H cam, headers, and advance curve kit? I am using original heads. Or should I stay with the factory recommended gap.
Thanks in advance
:cheers:
Thanks in advance
:cheers:
Re: Spark Plug Gap after intake/cam/headers upgrade? (desi)
Yur runnin HEI correct? The factory gap for HEI cars usually bigger anyway. Usually when you convert a points style dist to electronic, say for instance with the Pertronix Ignitor, they will discuss increasing the gap. The hotter more powerfull coil they recomend you use will allow for a larger gap. Thats the key, if you change to a higher output coil you can sometimes get better performance from a larger gap. For HEI, I would recomend .045 plug gap. if you gap too large with a weaker coil it can cause hard starting problems since the weaker spark may have trouble jumping the larger gap. The benifits of a larger gap would come from the longer spark trail between electrode and ground post. The longer spark is supposed to ignite the charge better.
Re: Spark Plug Gap after intake/cam/headers upgrade? (Jvette73)
Nope. the car still has points distributor. I have not heard/seen any hp gain from converting to HEI. This one works fine. I am just going to get a curve kit for it.....perhaps Lars or Accel.
[Modified by desi, 12:41 PM 5/1/2003]
