What paint for underside of hood ?
Old 05-23-2003, 10:09 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default What paint for underside of hood ?
Going to paint the underside of my hood, what paint should I use, want it to be as close to stock looking as possilbe. :D
Old 05-23-2003, 10:33 PM
ksbunting
Support Corvetteforum!
ksbunting's Avatar
Default Re: What paint for underside of hood ? (MotorHead)
I did my 68 hood with Krylon Semi Flat black spray paint, available at any hardware store. I think their part number is 1613, also price is around $3.00
I am finishing up a 6 year frame on restoration and have used various Krylon paints to achieve the correct shades as per my NCRS technical reference guide.
I have also received many recommendations from others on this forum before I started and was told that Krylon was the correct color shadesd and also of good quality so that is why I started using it.
I have not been disappointed.
Good luck
Old 05-24-2003, 07:27 AM
Paul L
Paul L's Avatar
John Deere Blitz Black. I picked up the tip from the NCRS Board.
Old 05-24-2003, 07:48 AM
R1234
R1234's Avatar
Here's a pic of my hood underside using the Krylon paint. http://temp.corvetteforum.net/c3/68r..._black_out.jpg
Old 05-24-2003, 11:54 AM
MotorHead
MotorHead's Avatar
Default Re: What paint for underside of hood ? (68rdstr)
Thanks guys
Hey Paul where did you get that paint ?
Should the underside be flat black or gloss, last picture looks kinda glossy ?
Old 05-24-2003, 12:06 PM
Paul L
Paul L's Avatar
Any John Deere machinery/tractor dealer has it. The paint is a semi-flat finish.
Old 05-24-2003, 12:31 PM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: What paint for underside of hood ? (ksbunting)
That's what I used. It dries fast & is easy to clean. It looks shinier than reality in the pic.
[Modified by 1970 Stingray, 12:33 PM 5/24/2003]
Old 05-25-2003, 06:49 PM
MotorHead
MotorHead's Avatar
Default Re: What paint for underside of hood ? (1970 Stingray)
OK got the Krylon Semi Flat black but the part number on the can says 41613, it is the right stuff isn't it ?
Also have the orignal sticker for the vehicle emission controls stuck on the underside and was wondering if I should paint around it or peel it off. I just had my car appraised and he seemed to think the original sticker on the door was worth keeping there. :D
Old 05-25-2003, 07:07 PM
gdh
gdh's Avatar
Put some tape over the sticker when you paint. That is the right Krylon, picked some up the other day myself.
Old 05-26-2003, 06:58 AM
Jughead
Jughead's Avatar
St. Jude Donor '09
Default Re: What paint for underside of hood ? (gdh)
You can also "paint" rubber cement or vaseline on the sticker before you paint the rest of the hood. Then once the paint is "dry", wipe off the rubber cement or vaseline.
Old 05-27-2003, 07:49 PM
Alwyn678
Alwyn678's Avatar
Default Re: What paint for underside of hood ? (paul79)
:seeya :cheers:
To What paint for underside of hood ?
Quick Reply: What paint for underside of hood ?
