High pitched noise from muffler at high rpm
Does anyone know what could cause this? When the car is idling and i rev to right around the redline mark I get a nasty high pitched rattling type noise from my driver side muffler. It sounds really bad. Just a few things, the muffler shop didn't install an H-Pipe, and just today i noticed the mufflers aren't mounted evenly. one if about 4 inches deeper than the other. I noticed this because I put some new chrome tips on today and one stuck out much farther than the other :P Nobody can get anything right!
But anyways, I'm thinking about taking my car back and getting an H-Pipe put in somewhere and moving the one muffler forward a few inches. Anyone have an cost etimates for this?
Also, I'd really like to know why the muffler is doing this...faulty muffler maybe?
St. Jude Donor '09
Re: High pitched noise from muffler at high rpm (SicChild)
An internal baffle or tube probably has broken loose. Had the same thing happen to a Summit house brand muffler on a S-10 pickem up truck....
Mike :cheers:
Mike :cheers:
Re: High pitched noise from muffler at high rpm (yellow 72)
Someone weld in some whistle tips when you were sleeping ?
Seriously, though - same concept. If the pipe was inserted too far into the
muffler, you might have a restriction or edges sticking out that can effectively
be a "whistletip". WhooooWhooo !!
Re: High pitched noise from muffler at high rpm (NHvette)
They are Flowmaster 40 Series Deltaflows....and it whistled even before I had tips on. Before the tips it was just the muffler outlet. It seems to be *slightly* better with tips on now.
