15X10 15X8 TIRE ?
15X10 15X8 TIRE ?
I need to know that tire will look right on my 15x8 wheels (front) and 15x10 with 295/50/15 in the rear i don't want the rear sitting to high
i want to keep a even hight
thanks :D :D
thanks :D :D
Re: 15X10 15X8 TIRE ? (cruzin)
the 2nd number is the aspect ratio (height to width), so if you change to a wider tire and the aspect ratio stays the same the tire will be higher. Select the widest tire w/ the lowest aspect ratio, then you won't sit very high in the rear.
A pic of my Corvette with 295/50-15 rear and 265/50-15 at front:
If you calc on it, rear: 295*0.50=147.5 mm and front: 265*0.50=132.5 mm section height.
147.5*2-132.5*2 = 30 mm = 1.2 inch diameter differens.
[Modified by Lasse, 11:13 PM 6/27/2003]
