Keisler 6 speed kit for C3 details !
Old 07-19-2003, 08:06 PM
0Robert Hall
Former Vendor
Robert Hall's Avatar
Default Keisler 6 speed kit for C3 details !
Here's the scoop on our 6-speed conversion kit for the C3.
4-speed manual to 6-speed conversion kit includes:
TRANS VIPER T-56 MODIFIED FOR CORRECT SHIFTER LOCATION
ACCEPTS MECH LINKAGE
USES YOUR BELLHOUSING
RATIOS: 1st 2.66 (2.52 for Muncie), 2nd 1.78, 3rd 1.3, 4th 1
5th .74, 6th .50
SHIFTER CORRECT LOOK HANDLE
CORRECT STYLE BALL FOR YOUR CAR
LOWER BOOT & TRIM RING
NEW DRIVESHAFT
MOUNT CROSSMEMBER ISOLATOR MOUNT
ISOLATOR
HARDWARE KIT
ELECTRONICS PACKAGE:
KIT FOR MECH OR ELECTRONIC SPEEDO, INCLD CABLE
REVERSE LAMP HARNESS
REVERSE LOCK HARNESS
PILOT BEARING PILOT BEARING (NEEDLE ROLLER)
INSTRUCTION MANUAL
TEMPLATE FOR TUNNEL PREPARATION
LASER CUT PANEL FOR TUNNEL MODIFICATION
NEW PIECES FOR CROSSMEMBER MODIFICATION
PRICE $4195 – THIS IS ONLY $800 MORE THAN OUR 650HP 5 SPEED CONVERSION!
The cross member requires modification which is detailed in the instructions. A 6"x2" slit needs to be made in the tunnel. The laser cut steel panel included in the kit covers the modified area.
A COMPLETE AUTOMATIC TO 6 SPEED CONVERSION KIT INCLUDING ALL THE ABOVE PARTS PLUS:
RECONDITIONED PEDAL CLUSTER AND PEDALS
BILLET STEEL FLYWHEEL AND BOLTS
MCLEOD DIAPHRAM PRESSURE PLATE AND BOLTS
MCLEOD PREMIUM STREET & STRIP RATED 11" DISC
ALIGNMENT TOOL
LEATHER UPPER SHIFT BOOT
LOWER SHIFT BOOT AND TRIM RING
RECONDITIONED BELLHOUSING AND BOLTS
NEW Z BAR AND CLUTCH LINKAGE
COSTS $800 MORE
The cross member requires modification which is detailed in the instructions. A 6"x2" slit needs to be made in the tunnel for clearance along with an opening for the sifter handle. The laser cut steel panel included in the kit covers the modified area.
[IMG][/IMG]
Quick Reply: Keisler 6 speed kit for C3 details !
