Just weighed my car, big suprise for GTech users
Old 08-01-2003, 11:36 AM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Just weighed my car, big suprise for GTech users
Just weighed my car with me in and half a tank of gas, no spare tire. The weight was 1350kg or 2970lbs. On the door it says GVW 3650lbs, looks like an adjustment might be in order for GTech HP meausement. :eek:
My read on this is: add another passenger 200lbs
add spare tire 40lbs ?
add half a tank of gas lbs ?
add cargo lbs ?
= ~ 650 lbs
[Modified by MotorHead, 10:40 AM 8/1/2003]
Old 08-01-2003, 11:48 AM
flood
flood's Avatar
Default Re: Just weighed my car, big suprise for GTech users (MotorHead)
wow thats really pretty light. I think the 80 model year was lighter than previous years due to more plastics and overall lighter material. Nice.
I want to weigh mine now. I just picked up a gtech and input 3500 for HP. Just a guesstimate from door reading. I wonder if on yours they just used the same tag as previous years?
Old 08-01-2003, 11:51 AM
Dwayne 76
Dwayne 76's Avatar
Uh oh.
Old 08-01-2003, 11:53 AM
Dwayne 76
Dwayne 76's Avatar
add cargo lbs ?
= ~ 650 lbs
GVW is weight of vehicle with full gas, and two (four) passengers. Right? Or did I mess that up.
Where did you get it weighed?
[Modified by Dwayne 76, 11:54 AM 8/1/2003]
Old 08-01-2003, 12:17 PM
desi
desi's Avatar
Wayne, look at the 'curb' weight on the same label. GVW (gross vehicle weight) is with all payload. Take curb subtract 200 lbs for passenger and guestimated weight for missing fuel, and adjust your weight (200 is what manufactureres use) accordingly. Should give you pretty close to what you are getting.
Where did you go btw?
Old 08-01-2003, 12:19 PM
desi
desi's Avatar
Default Re: Just weighed my car, big suprise for GTech users (Dwayne 76)
That's curb weight. GVW is max allowed weight will all payload.
Old 08-01-2003, 12:20 PM
Matt Gruber
Matt Gruber's Avatar
when was the scale calibrated last?
sounds wrong! my book shows a 77 at 3448, no 80's in it, i know they are a little lighter
Old 08-01-2003, 12:24 PM
gdh
gdh's Avatar
Default Re: Just weighed my car, big suprise for GTech users (desi)
It's all that helium that you pumped into your tires and butt to lighten the load for your 1/4 times at the track. :rofl: :lolg:
I am going to head to a weigh station today if possible and check mine out.
[Modified by gdh, 12:31 PM 8/1/2003]
Old 08-01-2003, 12:25 PM
joshs78sleeper
joshs78sleeper's Avatar
Default Re: Just weighed my car, big suprise for GTech use (Matt Gruber)
You know...I never understood....why the hell are vettes so heavy? I mean everyone thinks that since theyre fiberglass that they are light cars. And It would seem so to me too. Youve got a fiberglass body, youve only got two seats....so what the hell is it that makes them so heavy?
Old 08-01-2003, 12:28 PM
SCVetteGuy
SCVetteGuy's Avatar
Default Re: Just weighed my car, big suprise for GTech users (gdh)
Whoa, guess my hp measuresments are off!!! I put 3500 for my '80, with just me in it, and 3/4 tank of gas, and I still have the spare tire.
Old 08-01-2003, 12:29 PM
PRNDL
PRNDL's Avatar
desi is correct - I am surprised you have a GVW sticker in a vette. If you had a van with heavy duty suspension that was built to carry 2 tons, the GVW would be 2 tons more than the actual weight of the van. But coincidentally.... or maybe not, my vette weighs around 3650 lbs fully loaded (with me in it) MJ
Old 08-01-2003, 12:39 PM
desi
desi's Avatar
Default Re: Just weighed my car, big suprise for GTech users (MNJack)
MNJack, let's not even bring up GAWR (f) and GAWR (r). That'll really cause a confusion :lolg: :lolg: :lolg:
Old 08-01-2003, 12:43 PM
Cookwithvette
Cookwithvette's Avatar
Default Re: Just weighed my car, big suprise for GTech use (joshs78sleeper)
Just a guess would be the big, heavy steel frame. Also I forget what year but they started putting steel reinforcements in the doors as well.
Modern frame cars take advantage of hydroformed steel. Car manufacturer gets to use less steel and in return get a stiffer, lighter frame. Re-design our cars with a tubular chassis and I expect you'd see a decent drop in weight.
It's pretty ironic that fiberglass can be holding us back from having lighter cars. I'm talking unabody. Where the car IS the frame. This is part of the reason you can get a Honda Accord that seats four weighing in at 2,989 pounds.
Old 08-01-2003, 12:49 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
Default Re: Just weighed my car, big suprise for GTech users (flood)
Yes, the later C-3's are lighter due to a weight reduction especially in the doors, hood, and differintial.
Old 08-01-2003, 12:50 PM
dath
dath's Avatar
Default Re: Just weighed my car, big suprise for GTech use (Cookwithvette)
Of course I'd wonder what 600+ ft-lbs of torque would do to an Accord? There are good points to having a stout frame underneath the body...
Old 08-01-2003, 12:54 PM
gdh
gdh's Avatar
Default Re: Just weighed my car, big suprise for GTech use (dath)
Ever seen a Cobra with a 427 run at the track, I watched one last year blow the doors off Vipers, ZO6's and Agostino's race ready Camaro. He had only finished assembling it the weekend before and was getting some baseline runs in before he started to mod his car.
Old 08-01-2003, 01:13 PM
LAvetteman
LAvetteman's Avatar
Default Re: Just weighed my car, big suprise for GTech use (gdh)
Yes indeed, those cars are dangerously light. My buddy has a 302 in his and he has serious traction problems, still he runs high 12's.
[Modified by LAvetteman, 12:19 PM 8/1/2003]
To Just weighed my car, big suprise for GTech users
Old 08-01-2003, 03:20 PM
MotorHead
MotorHead's Avatar
Default Re: Just weighed my car, big suprise for GTech use (LAvetteman)
I just read the door label again and it says 3850lbs not 3650lbs and a capacity of 450lbs
Got it weighed at the city dump at Brittania and Terry Fox. I thought the scale could be off too but it is a city dump and it has two scales one wen you drive in with your load and one when you drive out they weigh you after you dump off your load so they know how much to charge so I imagine they are calibrated according to ISO9000 standards.
Maybe someone else can get their '80 weighed to confirm this
EDIT: actually I read the door one more time with my bifocals this time and it say MAx Load - 450lbs and 2 passengers, it kinda make sense now because at 200 lbs per passenger this adds up to 850 lbs, subtract that from 3850 and you get 3000lbs pretty close to what I got at the scales
[Modified by MotorHead, 2:30 PM 8/1/2003]
Old 08-01-2003, 06:23 PM
SCVetteGuy
SCVetteGuy's Avatar
Default Re: Just weighed my car, big suprise for GTech use (MotorHead)
I wanna get mine weighed, just dont' know where to do it.
Old 08-01-2003, 07:46 PM
MotorHead
MotorHead's Avatar
Default Re: Just weighed my car, big suprise for GTech use (SCVetteGuy)
Just go to any dump they have scales, weighed mine for free
[Modified by MotorHead, 6:50 PM 8/1/2003]
Quick Reply: Just weighed my car, big suprise for GTech users
