81' Drivers seat back stuck...help!
Old 08-03-2003, 10:53 AM
81' Corvette Guy
81' Corvette Guy's Avatar
Default 81' Drivers seat back stuck...help!
Hi all, my 81 drivers seat back is stuck in the upright postition?? Go figure, the left side is the side giving me the problem, went to put it down and moves bout .5 inches forward then lock..nothing moves! What gives? Short of removing the whole seat and tearing it apart not sure what I can do. This happen to anyone else? TIA for your valuable advise! While on the seat issue, how tough is it to pull out the cushions...any secret methods or tips to be had out here doing this..again TIA.
[Modified by 81' Corvette Guy, 9:59 AM 8/3/2003]
Old 08-03-2003, 11:32 AM
stickboy
stickboy's Avatar
Default Re: 81' Drivers seat back stuck...help! (81' Corvette Guy)
Mine does this sometimes, the inertial lock is not unlocking. To quickly unlock it you can pop the hinge cover off, then use a small straight blade screwdriver to unlock it by moving the lock toward the back of the car. The inertial lock is a white piece of plastic. Make sure it swings freely. :cheers:
Old 08-03-2003, 11:40 AM
sewright
sewright's Avatar
Mine does the same thing. I'll have to try to tip in the reply to this post. Thanks. As for taking out cushions, that very simple. Pull upwards on the back of the seat bottom. It should come up easily. Then just slide the front retainer out of the catch by pulling the cushion towards the back of the car. The top portion is also simple, just pull straight up on it. They are held in place by a long wire that catches on hooks that are molded into the seat frame.
Sam
To 81' Drivers seat back stuck...help!
Quick Reply: 81' Drivers seat back stuck...help!
