Broke a side post battery connector...
I thought the battery was dead. I put a wrench on the plus side terminal and when I pulled it, the bolt sheared off between the battery and the connector. The bolt is "frozen" in the connector and I can't turn it to get it out. I'm soaking it in WD-40, but don't think that's going to do much good. The battery corrosion appears to have "welded" the bolt to the connector. Anybody got any ideas?
BTW, When the bolt sheared off, it broke the battery case, so I'm going to have to buy a new battery anyway... Nothing is easy.
Re: Broke a side post battery connector... (Mack76)
if it is corosion from the battery soak the cable in water and baking soda. it may take a bit but the baking soda will get rid of the battery crap.
Steve :steering:
[Modified by stpman, 2:11 PM 10/27/2003]
Steve :steering:
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
I'd bite the bullet, toss it and buy new :leaving:
Re: Broke a side post battery connector... (jac1502)
because the case is broke i would not worry about it and just toss the battery and get a new one
Edit: What I'm trying to do is avoid buying a whole new positive battery cable.
[Modified by Mack76, 3:07 PM 10/27/2003]
You can't grab the lead part with vice grips or similar? If not, I would try to borrow a die grinder and cut the lead enough that the bolt can be removed. I despise those universal cable ends-I would do everthing I could to avoid those.
