Ques. on Threaded Toe adjustment in the rear - NO Shims!!!
Who has experience with the threaded toe adjustment for the rear wheels. This part partially welds to the frame, and eliminates the need for shims. I've seen them for sale through Guldstrand, but that is it. They installed one on the L-88 car on Dream Car Garage... Since I've got the body off the frame, now is the time to install if I'm going to...
Who has it? What do you think?
Second related question: Anyone use the spherical joint on the rear trailing arms? How much more vibration does it pass through? I would assume it is not going to be so great for the street, but want to check first....
Re: Ques. on Threaded Toe adjustment in the rear - NO Shims!!! (75 BBC Stingray)
75BBC,
"My opinion" (for what it`s worth!!). On the street both are a waste, on the track both are desired BUT there is (or was) a better designed spherical joint sold by Global West that actually used a spherical joint captured in a piece of tubing that got welded into the t-arm, I have the Global joints on my racer with t-arm shims but the next project (sitting in my barn right now) will get the Global (style) joints with the Guldstrand adjusters (I have a set of those also). ...redvetracr
I like the top ones. That looks like it would make an alignment better and easier on the shop doing the alignment.
Re: Ques. on Threaded Toe adjustment in the rear - NO Shims!!! (Eddie 70)
I like the threaded toe adjusters, although I've never heard of them before now. How much $$$ for a set of them anyway?
-Justin
-Justin
Are these the same thing as threaded strut rods?
I replaced my stock struts with Vette Brake poly bushing'd threaded struts. I love the quality and the results.
Re: Ques. on Threaded Toe adjustment in the rear - NO Shims!!! (Larry82)
Putting a spherical joint or cross-axis ball joint would be interesting. It'd transmit a LOT more noise to the car and would increase the loads that are seen at that joint. Can't see how that'd be a good thing on a street car.
It HAS to be easier than swapping shims from side to side - your alignment guy will thank you! :yesnod:
Re: Ques. on Threaded Toe adjustment in the rear - NO Shims!!! (Chris O')
What are the odds you could adjust those after a couple of years of driving? If you use enough anti-seize to prevent freeze up, do they retain their adjustment? Couple of things to think about before you throw out those shims.
Re: Ques. on Threaded Toe adjustment in the rear - NO Shims!!! (FeedVaal)
Good point. Thanks for all of the replies... I'll have to think about this a little...
BTW, I found this photo, which shows the TA and joint together.
[Modified by 75 BBC Stingray, 7:01 PM 11/17/2003]
