Winterizing
Winterizing
I was wondering what you guys reccomend as far as winterizing my 69 Vette. full tank of gas? oil change? any other little tricks of the trade that you might reccomend for winter. It will garaged for the winter time and not driven at all! what might you reccomend. i have kwiklift ramps to put it on, but further than that i am not quite sure. thanks
(Mark's son) Steve
(Mark's son) Steve
CI 3-4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Re: Winterizing (marks)
Hey! :seeya
This HELP section is for questions relating to the use of the forum itself. With a nice '69, you can ask the experts in the C3 Section:
http://forums.corvetteforum.com/zeroforum?id=3
:cheers:
:cheers:
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Moved from help section.
1 Post
Cruise-In V Veteran
Change oil and filter
Full tank of gas with Sta-bil or other gasoline stabilizer
Fresh wash (and waxing good idea, too)
Check air in tires
Disconnect battery
Some people cut up a bar of Irish Spring to put in interior to keep vermin out, but I don't do this one.
Others suggest moisture barriers, etc, but that depends on your storage area/facility.
Good luck and pray for a short winter
:seeya
Check air in tires
Disconnect battery
:seeya
