Replacement Carpet
Old 12-16-2003, 10:58 PM
dewayne4
Default Replacement Carpet
Where is the best place to buy replacement carpet for a 79?
Old 12-16-2003, 11:06 PM
swallace
swallace's Avatar
Default Re: Replacement Carpet (dewayne4)
So far I've had good luck with MidAmerica and The Last Detail. Just got carpet from MA and new leather and foam for the seats from TLD
Old 12-16-2003, 11:08 PM
Crash Dummy
Crash Dummy's Avatar
St. Jude Contributor
*The Last Detail* probably has some of the best prices.
Old 12-17-2003, 07:36 AM
mga1x
mga1x's Avatar
Default Re: Replacement Carpet (Winging It)
if and when you replace the carpet, take some extra time and install a heat/sound barrier through out the whole floor, including console sides, firewall, etc. some even use insulation for all the small nooks in the corners. i used a double foiled barrier. it came in a 4x6 foot roll. bought 2. and spray glued the pieces down. the carpet will lay nice over it.
also, in the engine compartment, your heater and a/c box is less than 2" away from the exhaust manifold. i glued a piece to that surface to prevent it from getting hot and radiating heat to the inside of the box.
you'll be amazed at the difference in heat and sound inside your car.
Old 12-17-2003, 08:18 AM
Edzred72
Edzred72's Avatar
:iagree: :yesnod:
Old 12-17-2003, 11:38 PM
Corvette ED
Corvette ED's Avatar
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,238 Likes on 1,032 Posts
Default Re: Replacement Carpet (Silvr77)
I got mine from AL Knock
Old 12-18-2003, 08:26 PM
NorthVette
NorthVette's Avatar
I got mine last year from Corvette Central but they were sourced from ACC... I was very pleased with the fit colour and quality... But all other vendors mentioned are quite reputable... If you're replacing other pieces of your interior (seats, door panels etc...) try to order them from the same vendor at about the same time to ensure colour match... I waited a couple of months between ordering most of my pieces and my storage doors and the red was a little different... Just afood for thought...
Good luck and have fun with your project!
Old 12-19-2003, 10:28 AM
markdtn
markdtn's Avatar
Default Re: Replacement Carpet (NorthVette)
TLD sources theirs from ACC. If they get it right it's a great deal. If not, ACC has substandard customer service.
To Replacement Carpet
Quick Reply: Replacement Carpet
