opinions wanted on an article I found on adding overdrive to a saginaw 4 speed tranny?
I found this article below on the internet. Due to my lack of mechanical and technical understanding of transmissions in general, I would like others opinions on this conversion to my saginaw 4 speed manual transmission. My vette has a Saginaw instead of a Muncie. Sometime in her past, the engine and tranny were replaced with a Camaro engine and tranny. The tranny has functioned very well, therefore, I have no need to replace it. If I could add an overdrive, this would solve my desire to reduce revs while increasing gas mileage. I had given thought to a T-5 swap until I found this article. Your opinions are greaty apppreciated.
"Finding a way to substantially increase gas mileage while retaining decent performance has become one of the toughest problems currently confronting hot rodders. It's not an impossible problem, and sometimes the easiest and least expensive solution amounts to taking a good look at what you already have and how it might be adapted to existing hardware. That's exactly what Don Dodge, an aircraft mechanic in Huntington Beach, California, did, and the outcome was really slick.
Don owns an early-model Camaro fitted with an LT-1 350 engine and a Saginaw four-speed transmission. It occured to Don that some very interesting similarities exist between the three- and four-speed Saginaw manual transmissions. For example, both versions use the same case, and the mainshafts are identical in both transmissions. (See Figure 1)http://www.chevytrucks.org/tech/ovdrive1.gif With these similarities, Don surmised that it might be possible to adapt the Saginaw overdrive (Chevrolet part No. 3924783), which was offered on '65-and-later Saginaw three-speeds, to his Saginaw four-speed. This overdrive unit is essentially a planetary gear system incorporated into the tailhousing of the transmission that affords an approximate 30-percent reduction in engine speed when it is engaged. If purchased new, this overdrive unit sells for about $200, but salvage yard prices should be considerably less.
Installation of the overdrive unit on the four-speed turned out to be quite simple. Following the Chevrolet shop manual procedure, the three-speed reverse, first and second gears, along with their associated synchronizers and hubs, were removed from the mainshaft of the overdrive and set aside. Then the tailhousing was removed was removed from the four-speed, and all of the gears, hubs, etc., on it's mainshaft were installed on the overdrive mainshaft. As we said, the mainshafts are identical, so this is a simple slide-'em-off/slide-'em-on operation.
Next, using the overdrive tailhousing gasket as a template, one hole had to be drilled in the mating face of the four-speed case for the overdrive shift rail plunger (item 26A in the overdrive exploded view, see Figure 2). The overdrive assembly, complete with four-speed gears, was then bolted to the four-speed case.
The next order of business was to weld a small tab to the reverse shifter arm. The purpose of this tab is to depress the shift rail plunger of the overdrive unit when the transmission is put into reverse. This tab, which goes on the internal end of the reverse shifter arm, has to be approximately vertical, as can be determined when the unit is assembled. The tab is required to disengage the overdrive in reverse or else the vehicle will not back up.
With the tab positioned and welded into place and the transmission side cover reinstalled, the completed transmission was then installed in the car. Since the overdrive tailhousing is the same length as the stock four-speed tailhousing, no crossmember or driveshaft modifications were required.
To control the four-speed with overdrive, the overdrive mechanical control had to be connected and mounted under the dash as indicated in the Chevrolet shop manual and the electrical connections and throttle kick-down switch installed as indicated in the shop manual wiring diagram. These controls allow positive mechanical lockout of the overdrive when it isn't desired, and the kick-down switch pops the unit back into direct drive, just like a passing gear, at full throttle.
Of course, an appropriate shifter was still needed. A Hurst four-speed shifter, utilizing the Hurst shift rods (available separately) from their three-speed overdrive kit will work just fine, although the four-speed reverse rod must be bent a little for clearance.
The completed conversion is rugged, reliable, quiet and effective. It will even withstand drag strip use with the overdrive locked out. With such an overdrive setup, it is possible to have a high numerical rearend for good performance and still have a livable final-drive ratio for street cruising and good gas mileage (see chart, Figure 2). For example, with a 4.11:1 rearend in his Camaro, Don is able to get in excess of 20 miles per gallon on the open highway, while the engine loafs along at about 2000 rpm at 55 mph in overdrive. Once again, hot rodding ingenuity proves that you can have your cake and eat it, too."
[Modified by Frankenvette, 4:01 PM 1/25/2004]
[Modified by Frankenvette, 4:04 PM 1/25/2004]
Re: opinions wanted on an article
I won't waste a dime on a Saginaw,basically they are junk. Hard to find parts for and weak. I know a guy who used to blow them up once a monthin his GTO. They were cheap so he would go get one at a junk yard and replace it rather then rebuild it.
Find a Muncie,ST-10, or go with the OD trannies.
Gary
Gary
Re: opinions wanted on an article (gtr1999)
Gary
Gary
Re: opinions wanted on an article I found on adding overdrive
If your tranny has held up well so far, then go for it. I think some guys at hotrodders.com have done this same thing. May want to ask around there.
Re: opinions wanted on an article I found on adding overdrive (applevette)
Re: opinions wanted on an article I found on adding overdrive (Frankenvette)
If I was you, I'd get my hands on a vehicle with OD and drive it around. Be real sure you like that sort of thing. I've got a '77 & an '85. The '77 has the 4sp & the '85 has the 4+3 OD. They are not the same beast at all. The only time I use the OD is if I'm on the interstate for a while. Otherwise, it's just the 4spd. Just decide if the work will be worth the rare use. Just my 0.02. :D
