17" Wheels
Re: 17" Wheels (77corvette)
Many here are running 17" wheels. If you stik to 17x8 wheels with 4" backspacing (0 offset) and use 255/50/17 tires you'll be a happy chappie. :yesnod: :cheers:
Cruise-In IX Veteran
Re: 17" Wheels (groovyjay)
That is exactly what I am running. The 255/50/17 tires are getting harder to find now though.
Re: 17" Wheels (Sigforty)
Wasn't the 255/50/17 standard tire on SS Impalas?
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
[Modified by SnoDrgn, 10:59 AM 2/9/2004]
Re: 17" Wheels (Tomi72)
That's my excuse for looking into 18" wheels with 255/45 tires :jester
If your search has been more fruitful than mine, please share your results.
[Modified by 75 BBC Stingray, 12:15 PM 2/9/2004]
I have 255/50-17 and am not too worried about finding replacements. If so, I could always step down to 255/45-17 and it looks fine too. (see 71roadster's car)
-terry
-terry
Re: 17" Wheels (terryrudy)
I am running 275-40 17 Kumo's on 17 x 9.5 Eagle alloys with 4.5" back set. No modifications were necessary. Rims were approx 165.00 from Wheels for less in Texas. Ran the same wheel all around so they could be roatated. Great for auto cross. Car wonders a bit on the highway so I would look into a 5" backset for the front.
They look sweet. Send me an e-mail address and I will send out a pic
Bronco Rider
Bronco Rider
Re: 17" Wheels (75 BBC Stingray)
I think you will find it even harder to get 255/45/18 for you car. 27" OD tires are hard to come by. I did a lot of searching on websites of many, many tire manufacturers, and by limiting myself to 26.5 to 29 inches cut my choices down dramatically. One of the few larger OD tires I found for the 18" wheel was the tire for the Ford Lightning 295/50/18, and at 29inches, this would be best for a rear tire. A matching front tire proved to be a problem.
[Modified by Tomi72, 9:52 PM 2/9/2004]
with the 255/45/18 tires you'll be bang on the 27" diameter. And you'll have good variety of different tires to choose from.
http://www.tirerack.com/tires/Compar...g=ZR&x=16&y=13
1 Post
St. Jude Donor '09
Boyd 17x8 w/ 4.5BS The tires are 245-50-17 and 255-50-17 rears BFG kdws 1500.00 shipped/mounted/lug nuts. You have to relocate the park brake cable to the inside of the trailing arm and move the bracket to the top of the arm( easy) Steve
Re: 17" Wheels (STLBLUES)
17" x 8" American Racing Torque Thrust II wheels with 255/45 x 17 Firestone Firehawk tires
4" backspace
[Modified by SAMMAN, 10:24 PM 2/10/2004]
4" backspace
