Where is starter relay located on75
Where is starter interlock relay located on75
where can i find the starter relay on my 75 i see it in the wiring diagrahm but cant find it on the car , also what kind of fuse is inline to the blower relay , red wire then fuse then orange wire , mine has been deleted and spliced together without the fuse , thanks for your help
[Modified by vette75406, 10:14 PM 4/26/2004]
Re: Where is starter relay located on75 (vette75406)
Confused. Are you talking about the starter solenoid as the previous poster described or are you talking about the starter interlock relay?
Re: Where is starter relay located on75 (KenSny)
yeah after i sent the email i knew i was confusing , the starter interlock relay , is what im after, thanks
The relay itself was located on the passenger side firewall in the engine bay. There is another post up today that has a link to pics. Also it is said that early in the '75 run this "feature" was stopped. My April car had the relay which I removed a couple of years ago. So maybe yours has it or not.....
Location: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
This may be the link.
http://forums.corvetteforum.com/zerothread?id=242627
Re: Where is starter relay located on75 (wackedvette)
thats it , i do not have one , ive seen it on other cars before but not on mine, guess i wont worry about it any more , thanks guys for all the help .
