Where do you get a M18 X 1.50 Metric Tap?
Old 07-01-2004, 01:33 PM
Kid Vette
Kid Vette's Avatar
Default Where do you get a M18 X 1.50 Metric Tap?
I recently had a couple bungs welded into my headers for O2 sensors. The threads shrunk down slightly when the bungs were welded so I need to run a tap through to open them up before I have them Jet-Hot coated. I haven't been able to find a tap. Any ideas?
Old 07-01-2004, 01:50 PM
BBShark
BBShark's Avatar
St. Jude Donor '05-'07
Default Re: Where do you get a M18 X 1.50 Metric Tap? (Kid Vette)
You could get one from McMaster-Carr (www.mcmaster.com). The bad news is it's probably about $30.
Old 07-01-2004, 01:52 PM
Gordonm
Gordonm's Avatar
You might get lucky at Home depot or something like tha tbut your better off finding a supplier who works with machine shops. I sell some cutting tools but not taps so I deal with industrial distributers all the time. They usually don't like to sell 1 tap but you might be able to work with them. Grainger should carry all the taps you need if they are local to you.
Old 07-01-2004, 01:58 PM
COMMANDER370
COMMANDER370's Avatar
Default Re: Where do you get a M18 X 1.50 Metric Tap? (BBShark)
Richards Machine and Cutting Tools
800-223-2689
p/n EP50-27793
Catalog i have shows 14.95.not sure if price is current.
J&L Industrial Supply
800-521-9520
p/n MET-13193C @ 15.84
25.00 MIN ORDER
in your part of the woods though.located in Livonia MI
[Modified by COMMANDER370, 7:00 PM 7/1/2004]
[Modified by COMMANDER370, 7:07 PM 7/1/2004]
Old 07-01-2004, 02:35 PM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Default Re: Where do you get a M18 X 1.50 Metric Tap? (COMMANDER370)
I don't know if this helps at all but, the 18x1.5mm thread is the same one that is used in the power steering gear pressure ports (gear inlet port) on the modern GM integral power steering recirculating ball steering gears (since 1980) and all of the GM rack and pinion power steering gears.
Old 07-01-2004, 03:02 PM
NHvette
NHvette's Avatar
Here is the answer ... thanks to someone here at work that recently did this :
Autozone (and perhaps other cheesey stores) has it.
Look for a sparkplug thread chaser - in the 'HELP' display.
It is double ended, but one is the 18x1.5.
Old 07-01-2004, 03:15 PM
markdtn
markdtn's Avatar
Default Re: Where do you get a M18 X 1.50 Metric Tap? (NHvette)
Or NAPA as a spark-plug tap. I bought one from them and tapped a cast-iron manifold when I put TPI on my 83 truck.
Old 07-01-2004, 03:32 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
Default Re: Where do you get a M18 X 1.50 Metric Tap? (markdtn)
a nut & bolt store. they sell tap and dies also
Old 07-01-2004, 03:35 PM
BSeery
BSeery's Avatar
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Don't even bother with Home Depot or Lowes. They don't have ANY metric taps, and very few standards.
Old 07-01-2004, 03:39 PM
GDaina
GDaina's Avatar
Check your Yeller Pages for Industrial Tools....they will have what you need
Old 07-02-2004, 07:00 AM
Jim Martley2
Jim Martley2's Avatar
I have one if you want to borrow it. I can mail it to you and you can send it back when you are done with it.
[Modified by Jim Martley2, 7:00 AM 7/2/2004]
Old 03-18-2013, 06:56 PM
Texas75
1st Gear
Texas75's Avatar
Default Metric Tap Option
Autozone has a M18x1.5 Thread Chaser for O2 sensors. It has a hex wrench head and a 3/8" socket head. Fits in tight spots and aligns well with 3/8" ratchet. The brand is OEM and part number 25255. Price is $10.
There are a bunch of these also by other manufacturers. Here is a link to some through Amazon:
Great Neck OEM 25255 Oxygen Sensor Thread Chaser - Amazon.com Great Neck OEM 25255 Oxygen Sensor Thread Chaser - Amazon.com
Old 03-18-2013, 09:20 PM
speedreed8
speedreed8's Avatar
surely he found one after nine years.
Old 03-19-2013, 10:10 AM
billsfan
billsfan's Avatar
It takes a speedreeder to remember to check the dates! Just remember, good information is timeless!!
Old 03-20-2013, 12:32 AM
Kid Vette
Kid Vette's Avatar
Thanks!
To Where do you get a M18 X 1.50 Metric Tap?
Quick Reply: Where do you get a M18 X 1.50 Metric Tap?
