Optima Battery
Old 08-17-2004, 06:12 PM
OHSIXX
Support Corvetteforum!
OHSIXX's Avatar
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Default Optima Battery
Will an Optima Battery fit in a 72 battery compartment?
Old 08-17-2004, 06:21 PM
Twin_Turbo
Twin_Turbo's Avatar
yes
Old 08-17-2004, 06:35 PM
Corey_68
Corey_68's Avatar
Yes, I have a Red Top in mine.
Old 08-17-2004, 11:59 PM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
I have the same in my 71.
Old 08-18-2004, 12:03 AM
Schmucker
Schmucker's Avatar
They'll fit, but I guess they aren't that great. I know of people that have bought them new and were dead. A guy that works at Autozone says that they get Optimas in the most for warranty, but they are sold the least.
Old 08-18-2004, 03:05 AM
Twin_Turbo
Twin_Turbo's Avatar
Yea mine went dead on half the cells and optima says I overcharged it. Since my car is apart I guess a miracle happened and it was telekinetically (sp?) charged I will never buy an optima again
Old 08-18-2004, 03:13 AM
ACECO
ACECO's Avatar
St. Jude Donor '04 & '05
Hummm, had very good luck with mine for the past year or so in the Camaro. It really made all the difference vs the old battery when getting it restarted when hot. The old battery, even though it was in OK condition, just wouldn't crank the starter over when it got hot and heatsoaked. Was just about ready to replace the starter with a mini, when my friend that is a mechanic said get an optima battery. Did so an now it cranks over fine, cold or hot. FWIW.
Guess like everything else, YMMV.
Old 08-18-2004, 04:15 AM
71coupe
71coupe's Avatar
Same optima since X-mas '98
Old 08-18-2004, 04:28 AM
Secret Squirrel
Secret Squirrel's Avatar
I've had a red-top since 2001 in my '85.
Run it flat countless times(c4 thing)... ....but it keeps comming back and holding charge
When my batt dies in my '69bb, i'll be getting an Optima for it
Old 08-18-2004, 08:01 AM
PB82CE
PB82CE's Avatar
Have my Red Top for just under 2 years, no problem to report yet...
Old 08-18-2004, 08:07 AM
James
James's Avatar
Yellow top in my 69 and it cranks the 509 over with no problems and runs 2 Spal 13 inch fans after the engine shuts off for about 3-5 minutes. Had for 3 years now and it went dead one time, charged it back up and have had no problems since. As with anything I think you will always have the chance of getting a lemon every once and a while.
Old 08-18-2004, 08:11 AM
L88-68
6th Gear
L88-68's Avatar
I've had one in my 68 BB for 1 yr with no problems...had problems with other batteries though. Guess it's the heat..should put some king of ventilation in the battery compartment
Old 08-18-2004, 08:26 AM
WeasleVette454
WeasleVette454's Avatar
Red top for my big block.
Weasle
Old 08-18-2004, 08:50 AM
Richard Cooper
Richard Cooper's Avatar
Got the red top in my 81 for 3 1/2 years now and no problems at all. It sits all winter and starts right up in spring.
BatManFire
BatManFire's Avatar
Yes it should fit but why?
I have owned a battery shop for over 30 yrs. I have seen new design batteries come and go (anyone remember the Torque Starter battery?).
Save your money and get a conventional type battery and replace them in 3-4 yrs. Anyone running a battery for longer than that is asking for trouble.
If you think you have some sorta wonder battery and it will last longer fine. My business also rebuilds alternators, starters and generators and we love people who take a battery too long, makes me a ton-O-money.
Here is a easy way I explain it.
An alternator is a battery maintainer NOT a battery charger. It charges really hard after start-up for maybe 30 sec then tapers back. If you have a weak/old battery these times are increased. The harder the alt charges for extended periods of time the more likely it will burn out.
Think of it like this. Say you start-up a new car and hold the gas to the floor just to the point where the rods are about ready to come through the block and then shut it down. Do you think that engine will last 100k now? Same principal here. The next heavy load against the alt (turning on headlights maybe) could be the straw that breaks the camels back.
I know some will say but it only makes common sense and I have seen this happen on a daily basis for over 30 yrs. Take your chances if ya want.
Old 08-18-2004, 08:59 AM
BatManFire
BatManFire's Avatar
Two of the worst things on a battery are heat (causes water loss) and vibration (knocks the plates loose). Eliminate those and you should get a battery to work flawless for 3-4 yrs. After that and you might as well buy a hard 6 or 8 at the local casino and see if it hits.
Old 08-18-2004, 03:27 PM
The Dude
The Dude's Avatar
Good old Sears Die Hard deep-cycle marine battery for me. In fact, I'm about due for a new one.
To Optima Battery
Old 08-18-2004, 06:38 PM
Boofers
Boofers's Avatar
I see your point but I have a question for you then about cold cranking amps. A local guy who rebuilds starters & alternators told me that for an engine with a high compression ratio you should replace/rebuild your starter with one that has high torque windings and also buy a battery with very high CCA. He said to do this because a higher compression engine will need these changes to start more reliably. Obviosuly he is trying to sell me stuff but to what degree do you feel this this is true?
Old 08-18-2004, 06:54 PM
crazcorkath
crazcorkath's Avatar
I have sears die hard gold in my cars. The warranty is just as good as an optima and they are a lot less money.
Old 08-18-2004, 07:17 PM
A C
A C's Avatar
Cruise-In II Veteran
An Optima red top fits fine in my 69 and works great. The last two conventional batteries I bought lasted 1 and 2 years before not holding a charge. Champion and Die Hard if I remember right. We'll see about the Optima. So far so good.
Quick Reply: Optima Battery
