What I did with my Saturday...Reflectix work *PICS*
Old 08-22-2004, 03:23 AM
BreauxBridgeKid
BreauxBridgeKid's Avatar
Default What I did with my Saturday...Reflectix work *PICS*
I know this is getting old, but this was a goal of mine since I first read of the product here and read of how effective it is on our heat isssue in the cab of our C3's. I've compiled some before and after pictures from the install, which took about 4 hours (with lunch break and easy conversation)
Old 08-22-2004, 05:25 AM
71coupe
71coupe's Avatar
Looks good
Seems like you are recovering ok from the incident last week
Old 08-22-2004, 09:02 AM
PRNDL
PRNDL's Avatar
I always enjoy seeing before and after pix!
especially when the "after" looks better than the "before"
Old 08-22-2004, 10:09 AM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
Old 08-22-2004, 03:14 PM
comp
comp's Avatar
are you doing the rear???
Old 08-22-2004, 06:46 PM
1970-Bronze
1970-Bronze's Avatar
Looks Good. Only 4 hours....? Man I need to do it then.
Old 08-22-2004, 06:56 PM
norvalwilhelm
norvalwilhelm's Avatar
Good job. I will have to do that this winter.
Old 08-22-2004, 11:21 PM
hdhamou
hdhamou's Avatar
Very nice, thanks for the pics. I am going to do this job in a few weeks and every bit helps.
Old 08-23-2004, 12:40 AM
80TexasC3
"Rodstoration &am p;quot; In Progres
Support Corvetteforum!
80TexasC3's Avatar
VERY NICE... I did mine a few months ago. You will like it!
Old 08-23-2004, 07:25 AM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Looks great. Where did you buy the Reflectix and how much did you need?
Will you glue the carpeting to this?
Old 08-23-2004, 11:32 AM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Cool deal, looks good. I did the same thing when I replaced the carpet.
Old 08-23-2004, 12:16 PM
BreauxBridgeKid
I bought the Reflectix at my local Lowe's Home Improvement. Also, I did a bit of checking and saw it for sale at Home Depot. I was able to do everything you see in the pictures with one 16" x 24" roll. Cost for the Reflectix, 3M Spray Adhesive, and Goop cleaning spray ect... was around $35.00.
Old 08-23-2004, 12:53 PM
SanDiegoPaul
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
How did you cut it? Put the roll in the car? Did you use the carpet as a template?
Old 08-23-2004, 01:14 PM
Corey_68
Corey_68's Avatar
I did mine as well, have yet to drive the car to see the difference in heat.
Total Cost $30 ($25 for insulation, $5 interior adhesive)
Old 08-23-2004, 02:17 PM
BreauxBridgeKid
What I did was cut 2 strips each 60" long...cut it off the roll with scissors. That length was just about perfect for the base floorboard from the topmost part of the firewall that I could reach to where the back wall meets the floorboard. I then cut another strip the same size and simply matched the edges from the floorboard strip next to the tranny tunnel and glued the stip against the tranny tunnel and press molded it as best I could up to and around the Parking Brake, Shifter and Radio. I used the other half of that piece that I cut to do the exact same thing to the other side of the tranny tunnel. Lastly with what I had left turned out to just be enough for the back wall...I think it was a 48" strip I cut and just cut and molded to back wall. Not hard at all easy stuff to work with, just was hotter than 2 mice doing it in a wool sock down here in South Lousiana, Good Luck
P.S. Definatly have a couple new Razor Blades ready for trimming and cutting while installing....works VERY well.
Old 08-23-2004, 02:28 PM
Edzred72
Edzred72's Avatar
Corey....Man...you forgot the MOST important part!!! Down by the drivers feet!!!! Wuzz-up-wit-dat???
Eddie
Old 08-23-2004, 02:33 PM
Wrencher
Wrencher's Avatar
When I did mine I just cut it with a large pair of scissors. I used 3M spray adhesive to hold it in place in key spots and then again on the carpet set. I also left the rear comparment area alone, but I did put a layer over the transmission on the inside of the tunnel. By the way, you know that foam collar over the bell housing? Fixed my hot shifter problem!
Hans
Old 08-23-2004, 02:50 PM
MEGALADON
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Darn, seeing those pic's make me want to do mine to
Old 08-23-2004, 11:09 PM
Corey_68
Corey_68's Avatar
Eddie
Well w/ my side mount headers, I'm not too worried. But I didn't want to add any under the pedals b/c I wanted to make sure the throttle would open completely. Sure the pedal can be adjusted but I did't want the peddle to be too "touchy".
To What I did with my Saturday...Reflectix work *PICS*
Quick Reply: What I did with my Saturday...Reflectix work *PICS*
