[MY OPINION] Discount Crate Engines..
I've actually posted that post in another thread.. but felt like posting iit as a new thread too.. Here's my take on discount crate engines:
You have to consider a few other things when judging discount builders engines including AR.. Many of those very low priced engines are built to withstand a certain HP and RPM level which will be close to the engines actual output. Inaccurate timing, tuning, install or aftermarket engine mods could easily cause damage to engines that are built to the limits of the internal parts. For example.. When I got my engine - I knew that my rods, pistons, crank, springs were only good to about 500 HP and about 6200 RPM... I had the engine installed by an ASE certified master technician (who also broke in the cam etc..). I went with their recommended carb, rev limiter and set the timing exactly to the specs specified by the engine builder. Maybe I got lucky that the engine held up so good.. but there's a chance that it held up that good because I did everything the way the builder recommended it. I know fellow floridian who also bought a engine from AR and he started having issues with his AR engine... (Don't remember what exactly the problem was).. I had some idea what caused the damage after he showed me some of his dyno sheets.. When they dynoed the car - they took the RPM to 7000 RPM on a engine that was rated 6000 RPM.. ...
No wonder that it broke..... (BTW - he told me that AR replaced the broken parts -even though it was clear to me that the engine was overreved on the dyno) There are so many factors that can cause engine damage and if you have an engine whose internals are rated close to the actual HP of the car - you better follow all the engine builders instructions and recommendations or you might get problems..
GS, of course right on with that comment there, funny thing is,....isn't that OBVIOUS??? second off, I feel there is little to no use for over 5500 rpm on any street driven car, just too hard on the merchandise, and of course racing is not covered by any warrenty I know of....
another good reason I left the track decades ago.....I like hearing race engines, burning someone elses cash that is.....
GENE
GENE
Well said Olivier! It's the old "you get's what you paid for".
But what IS a "discount crate engine"????
All the ones I've seen and priced sure weren't "discount" in my opinion. Wheeler, Shafiroff, Huntsvile, Ohio Crankshaft, etc., all cost big $$$.
Definitely taking an engine above the rated RPM is asking for trouble.
Dep
Dep
If a engine makes max HP at 6k and cannot be blipped to 7500 w/o grenading something is amiss . An engine underload will be happier at 7500 that one thats in ......... neutral
I don't like crate motors from anyones house . JMO . Me think it's always best to build your own . Buying crate motors comes in 2nd or 3rd or 64th depending where it comes from
You get what you pay for. I prefer knowing what is in the engine and how it was put together. You can't tell by looking at a crate engine that it has quality parts in it. It could have a cast crank crappy rods and cast pistons. Unless you take it apart you don't know. Crate engines are great for many and they have worked fine. I took my LT1 shortblock from GM and took it apart. Went to the machine shop to check it out. The bores were not round the rods needed some work. The crank was dead straight. It was not perfect by any means. It now sings to 7000 rpm without any problem. Not sure what it would have done in its as delivered state. Stay within the limits of the recomendations and you should be fine.
When they dynoed the car - they took the RPM to 7000 RPM on a engine that was rated 6000 RPM.. .....
what went wrong with his motor? unless they floated the valves they most likely didn't hurt it.
It appears that most engine problems are owner caused and by the bench racers, not the builders. Expecting high performance from a low compression hydraulic cammed engine to perform like a solid lifter 11-1+ or more. It ain`t gonna happen. Imaginary dyno sheets dont work. Speed costs $$$$$, but the most important item is the selection of the right combination of parts and the brains to make the most of it. Otherwise you may just have a high dollar slug.
Dep
Originally Posted by mountainmotor
Any engine needs be built stout enough for the occasional missed gear .
I know that you are a excellent engine builder and I ask you.. Can you build a 450+ HP small block engine that will hold up to 7500 RPM for less than $3k?? I know that you are able to build a engine that will hold up perfectly fine.. but could you do it at that price?
Hi Oliver... I've done my share of engine hop up over the years althought I'm a little more reserved now. Everything must be matched. The weakest part will determine the fate of the engine. There were always those guys that blew up there engines on a regular basis and never understood why. When you race, there's always the chance on something going wrong. Also keep in mind that some people can quickly destroy anything they get their hands on.
when it was said and done, and there was no more time to think about and dream of exotic engine set ups at give away prices.... i took my money to a local engine builder with a good reputation and a fair price.... as he said if you have a problem you know exactly who i am and where to find me.... i will pick up the 350/350 later this week... and i did mention i got to see the parts selected, partcipate in person in discussing the cam with the builder etc,etc...
Question from Oliver
Nope , no way . It would go over budget for the short block only .Engines need to be built bulletproof save for the odd unforseen component failure that happens with even the best of parts sometimes .
Homes built from the ground up with concrete foundations and footing stay the time vs homes built with sandstone foundations .
It's a big topic here with alot to talk about . There are junk components asked to do much more than designed to do then there are junk owners who can destroy anything handed to them .
Here is what I see most . I see engines that are never freshened up when it's time . There are many signs a engine needs to be pulled down , fresh parts placed into them , big end of rods resized ect but alot of people just run them in the ground .
street build vs race buildups
if the crate is oak or walnut it is top quality.
if it is white wood with cardboard it is junk.
fast for the dollar by far
Originally Posted by Homie
Good post GrandSport.
Sure hope my 406 from AR Racing holds up. The guy who is installing it said it looks like quality stuff.
I won't be revving it to 7000 rpm, trust me
My new engine that AR is building for me will be a fully forged short block that should hold up to severe abuse. Well - it's not priced at $2995... not even close...
IMO crate engines are a great way to go for most people, the thing you have to remember is we are talking about a wide range of performance level. The crate engine I bought was a custom crate from AR - 350 4bolt main, dart heads, comp cam, performer rpm intake slightly more then stock. I installed it set it up and started it up by myself (ok my wife helped) with no problems. Now if I were to get an engine that was at a higher performance level at some point I would need help or even need a professinal to do the set up and startup. So what I am getting at is IMO a lot of the problems people experience with these so called discount crate engines is because they do not have the knowledge or expertise to finish the job now don't get me wrong I have done the same thing and paid the price to learn the hard way, and I understand not all problems are self inflicted but if you have your ducks in a row your chances of success will greatly increase.
Dave
Dave
Location: San Diego - Deep Within The State of CONFUSION!
But as installed the engine cost me $5895.00 and that was built locally not purchased on the Net.
