Stainless Works C3 Small Block headers now available
We now have long tube and shorty headers available for the Small Block C3 Corvette. The long tubes are available with 1 5/8" or 1 3/4" primaries (the 1 3/4" are very close to the steering box but they do clear), and are completely tig welded, 3/8" cnc laser cut flanges, and are available with collectors ranging from 3 1/2" to 2 1/2"-we can also put a standard 3 bolt flange or size the collector to be a slip fit with the exhaust system. Prices start at $629, and hand mirror polishing is also available. http://www.stainlessworks.net/GM%20N...leflow_headers
The shorty headers are 1 5/8" primary tubes, and can be connected to the factory side exhaust with cutting and welding. They also feature CNC laser cut 3/8" flanges, completely tig welded, and have a 2 1/2" slip joint collector. Prices for the shorties start at $525.
We also make a true dual exhaust systems for the C3 which will bolt up to our headers-all 2 1/2" 304 s/s with dual turbo mufflers that use the factory hangers and have factory style outlets (for 63-73's), or turn downs for 74+. The true dual exhaust starts at $729.
As an introduction to forum members, we will offer free shipping on any of the above products, which will save you $30-70 depending on where you live. We will also take $30 off the price of the headers or exhaust system.
All of the above products are all 304 s/s, so they will be the last ones you will ever have to buy. All of our s/s products are backed by a limited lifetime warranty against defects in materials and workmanship. We do build all of these products to order, so please allow 5-6 weeks for delivery. We do not charge your card until the products ships.
Thanks and let me know if you have any questions. If the link does not work for you, let me know and I will email you any images you need.
The free shipping and discount is only good through the month of November.
Any chance of a 1 7/8 in. primary version ? Many big inch small blocks out there now and there is going to be even more in the future !
A picture of the blockhugger is at:
http://www.stainlessworks.net/images...k%20header.jpg
For a bigger tube than 1 3/4"-we would have to build them on the car. The 1 3/4" headers are very tight on the car and as we build them now I am 99% sure the 1 7/8" would hit the steering box. It would be so tight that we would need to build/weld them on the car so they would fit well. And, even with a big inch small block, you can make about 600 flywheel HP with a 1 3/4" header, and the gains from a really large tube header would be at pretty high RPM levels. But if you do need this we would be happy to build it on the car for you.
Let me know if you need anything else.
Do the shortie headers have round or square inlet holes ? I just bought a pair of Street and Performance stainless block hugger headers for my sbc that came with round inlet holes, my AFR's have these shaped exhaust ports:
I want to use these headers for a turbo application, but I'm concerned that they may be restrictive with the exhaust exiting the head into a smaller port (hitting the edges of the head tubes).
If you are building your own headers, why not get a set of flanges, grind them to fit the ports and then from round tubes make some starter cones, they are easily formed by hammering the round tube over a block that is somewhat pointy but gradually forms into a rounded square block with the same size as the ports. You'll only have to make 1 hammer form to do all the starter cones.
I must be missing something I am sure you can fill me in but aren't big block header at least 1 7/8 to 2in. collectors and more and they fit inside a C3 ?
You make some great products, I'm currently using your 3" in and out 304 stainless bullet mufflers mounted side by side out the center of the rear bumper on my 79. These are the best sounding pipes I've heard, and I've tried many. The quality is outstanding and I'll be sure to purchase your headers when my Hedmans burn out.
Price please...including shipment to Honolulu Hawaii 96816.
1 Set of Polished Long Tube 1 and 3/4" for a Motown 427 ci Small Block with Aluminum Heads.....
Do I get a break in price for distance to your shop from the other side of the world?
I would buy a set if they don't go much lower than my 7" deep Corvette oil pan (note to the aftermarket: The Corvette is a "sports car" and it's oil pan is only 7" deep from the factory for a good reason!.) Everyone seems to have a problem with the depth of hedders for a C2-3 Corvette. I Emailed Stainless Works with the question, I like the design but won't buy them if they end up scraping at every speed bump I encounter.
Motorhead
You are right-we make a 2" big block header for the c3-the problem is that the big block head exits on angle, so the tubes do not come out of the port and crash directly into the steering box-we can make the tubes go around the box by cutting and welding three pieces into one tube-they are still tight but actually you have more room with a big block because of the way the cylinder head angle is different. I did not say it couldn't be done-I am sure we can do it, I would need to have the car to do so because I can't change the tube diameter of the header and build it in the jig we have already-the jig is designed for 1 3/4" or smaller tubes.
As far as ground clearance-we made these headers fit as close to the floorpan as possible. The problem is that with a long tube header the collector will hang down slightly due to the way the floor pan is designed-there is no way to make the header push up any higher than we have them, unless you want the collector laying against the floor pan and burning through the glass, which I am sure you don't want and neither do we.
If your car is lowered a lot, I would recommend putting shorties on it-you will still get the ground clearance you want and they will flow better than the factory cats iron manifolds.
We also can laser cut flanges to a gasket template-in 3/8" s/s we charge $125 for the flanges and a $50 fee to digitize and create a .dxf file which our laser cutter uses. if you can supply a clean .dxf file the flanges would be $125.
Al
Al
Alnoe,
I like the design of these Stahl side exit headers, but they're pricey for carbon steel and probably more performance directed than I require. Just a ballpark fiqure; how much are we talking about for custom headers built to my car of a simular design?
