is there a anti-theft relay on a 1972 ?
Old 11-14-2004, 01:26 PM
machineg
machineg's Avatar
Default is there a anti-theft relay on a 1972 ?
I have a 1972 corvette, I have just replaced the battery. My Car will turn over great but will not start. it acts like there is no spark. Is there an anti theft relay ? or switch any help would be great... Thanks everyone
Old 11-14-2004, 02:19 PM
Gordonm
Gordonm's Avatar
No not in a 72. Check to see that you have voltage at the coil when the ignition is in the on position. There is a resister wire tha tgoes to the coil that sometimes burns up.
Old 11-14-2004, 05:03 PM
machineg
machineg's Avatar
I have just replaced the coil resistor, and tried to start again- NO starting. I put a tester light on coil and as I turn it over the light flashes. Anyone hace any more ideas ? HELP
Old 11-14-2004, 06:31 PM
Gordonm
Gordonm's Avatar
Pull one of the plugs and see if you are getting fire at the plugs. Ground the plug to something on the engine and have someone turn the car over and check for spark.
Old 11-14-2004, 08:37 PM
machineg
machineg's Avatar
Yes, I Just tested and yes I do have a spark
Old 11-14-2004, 09:34 PM
trw
trw's Avatar
Anyone have gas?
Spark, gas and air = running motor.
Old 11-15-2004, 06:44 AM
Gordonm
Gordonm's Avatar
Originally Posted by trw
Anyone have gas?
That would be my next thing to check. Are you getting fuel to the carb?
Old 11-15-2004, 02:16 PM
machineg
machineg's Avatar
Anyone have gas?
Ha Ha I wish... today I will try Reconnecting the ground and a new condensor.. plus cross my fingers. My Son is comming up next week for the holidays. He helped Me pick the car out last summer. I sure hope I can get it running for him.
Old 11-15-2004, 09:42 PM
trw
trw's Avatar
If you are getting spark at the plugs and gas when you push the pedal. You should not have grounding or condenser problems.
Was the car running before the battery change? Could it be a timing issue?
Terry
Old 11-16-2004, 12:42 PM
machineg
machineg's Avatar
The car battery died while on my was to work, I got a jump and drove it home. I took out the alternator to have it tested. it was fine. I purchased a new battery. 40 amp to 100 amp. Car would turn over just fine. I replaced, coil, resistor, condensor and points. I have spark to #1 and have it timed. I have gas coming out of the jets. grounded the block. I'm giving up this afternoon and having the car towed to get fixed. after 15hours and alot of running to the parts store I'm defeated. Thanks for your help. If you think of anything before this evening let me know. I tried all your suggestions
Old 11-17-2004, 03:32 PM
machineg
machineg's Avatar
I got a call from the shop, I guess it was not electrical at all. My new Edelbrock card, less than 200 miles needle broke ? totally flooded all the time. SUCKS, but al least it will be fixed and I can drive tonight - YEA!
Old 11-17-2004, 09:42 PM
trw
trw's Avatar
congrats.
That might have been something you would have chased forever.
Terry
To is there a anti-theft relay on a 1972 ?
Quick Reply: is there a anti-theft relay on a 1972 ?
