Big Block rebuild options...
As I sit here I have time to think about what to do about the 454 in my car when I get back home. I know I can check it out and decide to rebuild or not... But what about dropping in a new mill and putting the orginal one on a stand in the garage? I see that GMPP sells a 454HO for ~$4700. This motor supposedly takes the mechanical (stock) fuel pump and also has the hole drilled and tapped for the clutch stud. I want both these features. I'm not sure that the 502HO or the ZZ502's have them. I do like the Gen VI blocks and the one-piece rear seals... What other GM crates have what I want and what other motors are recommended for consideration? What is a ballpark price these days (I live in St Louis) if I go through my old 2-bolt main motor myself and take it in pieces to the machine shop for cleaning, boring,etc...? I have done this before and the costs just add up. I would want ~9.5:1 compression hypereutectic pistons, new cam bearings and all the routine machine work to include balancing, a good torque cam (never racing, just good street power down low in the rpms) and I would use my stock heads (unless buying a crate long block), intake and exhaust manifolds. Such fun to even consider these choices! I love it!
If you do go with a Gen V or VI crate, you can always go with an electric fuel pump, and get a clutch bracket from Scoggin-Dickey Performance Parts.
Here is a link to Scoggin-Dickey
www.bigdogvettes.com
It bolts on the bellhousing, goes around the oil filter and put the pivot ball right where it should be.
I'm running this on my Gen V block with no problems.
The 454H.O. is a hell of a deal, 450hp/500tq, pump gas friendly, forged rotating assembly and 4 bolt mains.
CI 5 & 8 Veteran
Dave, sounds like you are thinking about some of the same things I was about a year ago. I went thru my original 454 rebuilding it much the same as you discribe....."9.5:1 compression hypereutectic pistons, new cam bearings and all the routine machine work to include balancing, a good torque cam"....only to put it on the shelf and buy the RamJet 502 GM crate motor. I decided I wanted all the latest technology ( roller cam, aluminum heads, fuel injection etc) I am glad I did. If I had it to do over though, I would probably have opted for the ZZ502 with aftermarket fuel injection such as Holley's Commander 950. That would have saved me alot of work raising the L-88 hood 1". Plus I would have had a more versatile FI setup and control. The intake wouldn't have looked as bad azz though
Bullshark
Bullshark
Bullshark - superb job! I live in Kirkwood, MO, so I'll have to check out that car in person when I return home! Where did you have the work done on your stock motor? Happy with them? I'll have to mull it all over - that's half the fun!
Thanks!
Thanks!
If I had it to do again, I might just get the ZZ/454 with the aluminum oval port heads and 110 cc chambers. The GM 454 is DEFINITELY the best bang for the buck, IMHO.
Senior Member since 1492
I was thinking of going with the 454HO when I crossed that road. I didn't have the cash and didn't want to use a credit card. I had to purchase pieces and parts as $$ & time allowed. I also didn't have a hoist at home to off-load the delivery truck. Lot of other reasons too prevented me from going crate. Good luck either way.
Bullshark & Massvette have two of the nicest vette's on the forum.
Same with me. Still trying to piece together my Big Block as I can afford parts.
Buying a crate is the best way to go, especially when it come to warranty work. Be sure to let us hear what you do!
Another option for the clutch with the Gen V & VI is to use a hydraulic clutch release. The only thing about that is that you have to get the bellhousing that supports the slave cylinder.
I'm in the same boat as a few others. I would go the GMPP BB crate but due to the lack of cash I've been looking for a good used block. I found a BB in a pickup but the guy wants $800 for the engine. When I add the cost of machining alone brings the block to around $1500. Add the cost of parts and the GMPP begins to look like a bargain. If I could find a BB for around $200 then the costs begin to line up.
CI 5 & 8 Veteran
Jughead
Matchframe
problemenko
Guy's.... what are you trying to do! It took me 30 years to train my wife to the importance of Corvettes over such material things as home improvements, flowers, jewlery etc. If she gets wind of this post, I'm hosed
Bullshark
Bullshark
St. Jude Donor '11, '16-'17
My '69 bigblock Nova ended up having a freeze crack in the block (bought it this way at an auction ). I was hoping to take the crank and heads and put them in a 454 block and get a 427. After talking with my builder, he said he didn't want to use a cast crank for the HP I wanted and he convinced me to sell the parts on ebay, and build a 496. It will cost $6k, but I will also get a lot more HP than a crate and I know this guy absolutely doesn't build junk. Most builders have access to cheap cores, so you really don't need to find your own block.
CI 5 & 8 Veteran
Originally Posted by problemenko
Bullshark, it's the college tuition bills that are here for the next few years that put a dent in my fun funds.
Good for you That will pay big dividens in the future. Maybe enough for your Corvette Hobby AND the wife.
Bullshark
Originally Posted by Bullshark
...Guy's.... what are you trying to do! It took me 30 years to train my wife to the importance of Corvettes over such material things as home improvements, flowers, jewlery etc. If she gets wind of this post, I'm hosed
Bullshark
Bullshark
If I had a job where I was making money, I could go out and buy parts....right now I am just trying to put food on the table.
12.14 w/ the original 327
I was going to build a 454 for my GFs Malibu. After comparing costs, I ended up building a 496 using Speed-O-Motive for the rotating assembly. Carb to pan, including ceramic coated headers, I'm in mine about $4500.
496, 10.2: forged probe light weight pistons, longer rods, Engle cam, #781 Oval Ports with 2.19 and 1.88 valves, 1 3/4 Hedman Elite headers, it currently has an Edelbrock RPM intake and a Carb Shop stage 3 #3310 carb, but will ultimately have a '68 oval port tri power set-up on it.
