Repost: '69 427/435hp Tri-power, 4spd, $32K... Good Deal?
There is a '69 427/435 for sale here in Tampa. The owner rebuilds corvettes and has had this car for some time. Maroon exterior, black interior, t-top, 4-speed, 427/435 matching numbers with 3 deuces. About 62K orig miles. The car looks very clean and straight inside and out and pretty immaculate under the hood. He has been asking $30-32K for some time now and my guess is the right buyer hasn't come along.
Good deal?
This may sound crazy but if I were to buy it, I'd want to drive for pleasure often. Would this much engine require de-tuning to run on 93 octane?
Good deal?
If the car is a true numbers matching 435hp in good shape, I think that 30-32K is fair. As for the gas, fi you need to, you can get additive to boost the octane and/or add lead or lead substitute. I did it for a 70 LT-1 I used to have and it wasn't a big deal.
Originally Posted by Van Steel
Ted
If you want, you can bring the car by and we can throw it on a lift if you'de like.
All,
Thanks for the good feedback. I'm going to 'casually' pass the '69 427/435 by the wife when she gets back from Christmas shopping...
I stopped over at the store today; had to have my mounted seat covers clipped into place. They took care of them for $27. What a deal.
I asked about the 427/435 and they definitely still have it. There isn't alot of demand for it since, in the owner's words "It's not a warm-weather car, it idoes better in colder climates where it won't overheat in heavy traffic". They also mentioned that a crack developed in the right front quarter panel due to the "'twisting' of the frame from the engine...". They claimed this is a common problem where the big-block cars with considerable torque tend to crack the front quarters; requiring body repairs. Apparently, they are going to repair the cracked body panel very soon.
Will keey y'all advised.
St. Jude Contributor
Body cracked because of engine torque? BS, in my humble opinon. And a big block engine in good condition, with a radiator in good condition, should not be overheating, even in Florida. I'd definitely get that car checked out before I turned over a dime. With 62K miles, it should be in damned good condition (I've got 52K original on my car, and the upholstery and carpet show little wear and the car is very tight--no rattles and the steering is very positive). If that milage is correct and there are no other real problems, 30K is a good deal IMHO.
JB
JB
Originally Posted by TedH
All,
The place your talking about sells Vettes that have been in accidents and rebuilt. Some have been totaled , others come pretty close. I wouldn't be suprised if that Vette has been pretty F'd up at one point in time. The do have good prices, though.
I've seen that Vette, it looks, real nice. It's been there for like 3 or 4 years.
If you're truly interested, get it checked out by a third party. Body cracking from the torque? BS. It might if the frame is rusty. No vehicle should ever overheat regularily if at factory specs. Maybe if the engine was actually wild it would, but it is just a stock engine.
Just make sure to ask for proper documenttation, LOTS of clones out there.
As far as the "Stress Crack", it does happen, but this is seen mostly on cars with radical cams. 35yr old fiberglass that has been heated and cool w/ the weather changes + a radical cam with serious lope can and will cause minor stress cracks. I can vouch firsthand with this info.
Good luck.
Good luck.
Good luck.
Good luck.
All,
If I go to the next level on this car, I'll definitely take it over to Van Steel for an examination on the rack.
Danny, you folks real busy this week? I know anything after Thursday runs into Christmas. Thought I should check now...
Body crack
Partner, that cars got a steel welded ladder frame, the body is rubber mounted, the 427 is rubber mounted on either side to that ladder frame and if it gets away you chain it (to the Frame). There realy is no conection from the Engine to the body unless you count the wiring harnes or the flimsy linkage to the gear shift or to the carburator / clutch, non of those are gonna crack the body. I owned a 1968 427 that would literaly burn a pair of tires off! No body cracks, he's makin up something, it's just a flat lie. Buyer Beware, dat ting was wrecked......
Yep, that's the place. I used to drive over just to look at it and and drool. If I go the next step, I'll take it to Van Steel for closer inspection. I'll also be asking about accidents/damage. I think they have to make that known (if they know), don't they?
I know on their web site they clearly tell you that a car has been totaled, but they dont say anything about how much damage it might have recieved if it was not totaled. That would be a nice drive across the bridge to Van Steel, anything thats wrong would show up on that trip I would think.
Premium Supporting Vendor
All,
Bring it on down
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
I bet they know who Van Steel is
Tell them you would like to take the
car to them for inspection, then see
if they hesitate, or spill the truth
they may have kept it that long for a reason.
Corvette Shop and Supplies on Dale Mabry Hwy.
Quick update, my wife talked me into waiting until I finish the '80, sell it and have money in hand. We can't afford the $30K debt. My head says she is right but my heart's hurtin' anyway.
Thanks for all of the good info!
P.S. Not sure if I had posted this info:
True L89 t-top coupe.
Never wrecked (at least no record of it)
Original engine/trans, engine rebuilt at least once.
