Howard Stewart water pumps
Old 12-23-2004, 06:27 AM
73jst4fun
73jst4fun's Avatar
Default Howard Stewart water pumps
Anyone using the Howard Stewart aluminum pumps I see on Ebay? How do they compare to other water pumps, Edelbrock, Milodon, etc.
Old 12-23-2004, 08:26 AM
isosceles
isosceles's Avatar
Is that the same as Stewart components? If so, I had a high flow aluminum pump, stage II. It started leaking a little over a year since I installed it. It could've been that my motor mount broke at the Corvette Challenge and I heard my fan it the shroud. That could've tweaked the shaft and cause the leak, but who knows.
Old 12-23-2004, 10:23 AM
Hitch
Hitch's Avatar
I've got a Stage II also and have had no problems with it. I believe it was money well spent.
Old 12-23-2004, 11:57 AM
FINWOLF
FINWOLF's Avatar
got the stage II no proplems. it pumps more water then stock.
Old 12-23-2004, 12:27 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
interestingly my ELGIN cast aluminum water pump came with shinny marks where the manufactures name and casting number had been grinded off.....wonder who made my pump????
Old 12-23-2004, 04:46 PM
73jst4fun
73jst4fun's Avatar
These pumps are on Ebay and sold by Performance liquidators, they give a pump #23103 to compare to...made by Stewarts Components (Howard Stewart) out of High Point, NC...that's all I know of these pumps...
Old 12-23-2004, 05:19 PM
Glassbowtie77
Glassbowtie77's Avatar
I have the Stage II Also. I bought it on Ebay brand new for $79.95. Stewart's website has it listed for $159.95, I think I got a good deal, will let you know once I am able to drive it again. From what I've been told they move alot of water and are supposed to be one of the best water pumps out there.
Old 12-23-2004, 05:29 PM
66CorvetteCoupe
66CorvetteCoupe's Avatar
Default Stewart Pumps
If Stewart is good enough for Nascar Engine builders they are good enough for me. I am running one on a 427 car seems to work good.
Gerry
Old 12-23-2004, 06:47 PM
73jst4fun
73jst4fun's Avatar
That's the one I have been looking at to buy, seems like a good deal, didn't know anything about the seller except for the feedback, did you have to change the thermostat, I think they recommend to change to a high flow thermostat....
Thanks to all for your imput
Old 12-23-2004, 08:22 PM
427V8
C6 the C5 of tomorrow
Support Corvetteforum!
427V8's Avatar
I went from a stock rebuild to a stewart.
This is on a 460 hp 434 running the stock radiator.
There was no difference in cooling at idle or speed.
It is a nice pump tho...
Old 12-23-2004, 10:50 PM
Hitch
Hitch's Avatar
I didn't know that they made them in High Point... I thought the company was located in MI. I have to say after installing the stage II and a DeWitts I have not a neary temp problem. Dave.
To Howard Stewart water pumps
Quick Reply: Howard Stewart water pumps
