Fusible link at starter. Replace or bypass?
I'm troubleshooting a starter issue and noticed that the (starter's)fusible link insulation, although intact, appears "gooey" from all the years of gunk/heat/oil exposure. Can I replace/bypass the link with matching gauge wire or must I install new?
Where the heck does one obtain a fusible link?
D. Ocean
Miami, FLA
D. Ocean
Miami, FLA
Originally Posted by markdtn
Replace. They can be bought at any auto parts store. Probably easier to find at NAPA or CarQuest.
make sure you have the corect gauge wire.....
Originally Posted by hosspowerinc
Id replace it with a push-in fuse. Use the right guage wire and the right fuse. Fusible links burn and can cause fires. Fuses wont.
D. Ocean
Miami, FLA
