Intake Manifold Torque Specs
Could someone tell me the correct torque for a 1970 LT-1---350/370 intake manifold bolt? The shop manual lumps all 350's together and does not separate the aluminum intake from the cast---thanks---I have the day off and am diddling on the Vette in the garage---oh what fun it is
SEMPER FI--1970 Dave
i torqued my aluminum one to the same specs as the cast iron one...never gave it a second thought....
I have never torqued any intakes in my life. Most of the time it is to difficult to get a torque wrench in there. I have always made them just tight. Never had one leak. I do follow the tightening sequence though.
-Mark.
Eddie
Senior Member since 1492
When I mounted my Stealth aluminum, I think the specs were 30ftlb according to the sequence.
St. Jude Donor '05
I've never used a torque wrench on my intake.. I usually tighten the intake pretty tight...
Originally Posted by pcfred
Do you use sealer? What brand gaskets do you use?
