LT4 HOT Cam in a "Standard" SBC?
Hi,
I have a used LT4 HOT cam in my garage that I had originally planned to stab in my '94 LT1 powered Trans Am. But I traded that car for my current '82 Corvette.
So I was wondering if I can I use this cam say in a crate motor that already has factory hyd. roller lifters, or even an older SBC with aftermarket hyd. rollers? I believe it should work, because I've heard that the ZZ430 crate used the LT4 HOT cam, but I'm not sure if its *exactly* the same cam, or if it may have just shared the LT4 HOT lobe profiles. Just need to get a "warm fuzzy"! TIA!
Originally Posted by Schmucker
I think it'd work, the only thing I'd worry about is whether it has the gear to drive the distributor as the LT1s had optispark.
I thought there were slight differences in the drive end, using a thrust bearing behind the gear or something odd like that? Also, see if it has a fuel pump drive cam if using a mechanical pump. Joe
i used a crane needle bearing cam button between the cam and timing cover, and used a roller bearing behind my timing chain cam gear.i also know of someone that has the hot cam in his and he uses a mechanical pump.But check anyway to be extra sure.
Thanks for the replies; you guys brought up some good points about the distributor gear and mechanical fuel pump (even though I would probably retain the stock electric pump in my '82's tank and regulate the pressure as needed).
So, I went out to the garage to check out the cam, and it does have the eccentric lobe for a mechanical pump as well as a normal distributor drive gear. Of course the cam is machined from billet steel (instead of cast iron) so I may need to run a special distributor gear as mentioned above.
Are there any other things I need to check out? I also noticed on the front face there's a 90 degree step milled around the circumference, so the timing gear mounting surface is a smaller diameter for some reason. Any ideas about the timing gear I would need to run?
I bought my LT 4 "Hot Cam" from my friend that was running it in his 383 stroked LT1 for a short period of time - decided he needed more power. It fit directly into my ZZ4 block with no modifications. I run a standard HEI distributer and a mechanical fuel pump. So, I would think it would work in any other SBC that was machined for a factory roller cam.
Jason yes if he puts it into a already factory roller motor then yes put it in use the cam plate and oem lifters hell be fine,but if he puts it into an older block hell have to make the changes especially retro roller lifters.The zz4 motor already came setup with roller cam and the right gear for the dist.
