327 id questiones
327 id questiones
After getting nowhere with this question in OT, i'll try it again...
ok, I just pulled the motor out of my 69 vette. The original motor was replaced it with a 327 (I knew this when i purchased it). Now that its out, i know the casting number on the 327 is 3914660 and has a casting date of t14. I searched a couple web site and im still confused where this 327 originally came from. Some sites say a truck others said chevelle, camaro, novo.
Could someone please let me know what it is out of? Any advice on what this motor (with heads and intake) is worth would be appreciated too.
Carl
Carl
We need the suffix stamping from the front of the block. It is the area in front of the passenger side head. With that, we have a good shot at ID'ing the engine.
The 2 letters after the assembly date code stamp is needed.
-Mark.
-Mark.
Cars and Parts Chevy V8 Casting Numbers book says 68-9 327 Pass, Chevelle, Camaro, Nova, Truck. It's 4.0" bore large journal block. It will be 2-bolt mains as no 327s were 4 bolt. If you are going to build a 350 why not just get a 350 crank and build this one? It is period stuff, probably decent material. I doubt you will get more than $300 for the engine (maybe a little more depending on the intake). I'd use it if I could.
More info on the 327
ok here is what i got...
in the front of the block: 18c120363 and t0208hf
back of block: gm 3914660, b 7 8, t14, conv1, aroow pointing at dot 5 out of 11.
behind fly wheel and clutch: t h9, u, 660, 638
I don't plan on rebuilding this motor im just trying to figure out what it is before i sell it. I plan on building a 427 to place back where it belongs.
Thanks for all the help!
Carl
Carl
