NOS Dyno Results
NOS Dyno Results
Just ran my 1990 - L98 on a Mustang Dyno, Base line HP was 268.4hp with 319.3 torque, 100 Shot produced 341.6HP with 414.6 Torque and the 150 shot provided 361.6HP with 452.7 torque. Also had the oppertunity to meet Mike Wood of NX systems at the shop as he was getting some work done on the NX Mustang.. This man is very knowlegeable. He showed me the difference between a NOS system and and NX system.
90Indy
nice numbers, did you pull any timing?
I saw some guy at the track with an l98, I believe he had a 150 shot, he was running 12.7's and I did find out that the track was fairly poor last friday.
My A/F was out, I was too rich. I will get the exact numbers on Monday. I was impressed with the baseline and the 100 shot but the 150 is less than expected. Left the timming as it was. No bottle heater and no pressure guage.
268 at the wheel with a exhaust system?
.....the car is not stock...especially on a mustang dyno, which typically give lower hp numbers. A stock '90 makes what....~240 flywheel hp? You are making more at the wheels than the engine was rated at the factory flywheel with just an exhuast?
If you have not owned the car your entire life, then somebody modified the motor.
Good numbers anyway!
