FMU Problem
04-21-2013, 03:05 PM
Cruising
FMU Problem
I have procharger FMU,it suddenly stopped increasing fuel pressure.
Where should I start looking for the problem?
Sami from Finland
04-21-2013, 05:46 PM
First I would check the vacuum line running to the unit. If not that I would check the diaphragm inside the FMU.
05-12-2013, 04:08 PM
Cruising
Now I got a new procharger FMU and the problem seems to be that the fuel pressures does not go higher. FMU works after the boost pressure is about 5 psi.
