BOV on procharger p600b?
Old 01-12-2014, 07:49 PM
smooth1990
smooth1990's Avatar
Default BOV on procharger p600b?
I want to get rid of the bypass valve on my intercooled, procharged 1992. I have done a little research and the procharger red BOV looks like the direction I would like to go.
My question is, Where is a good spot in the over the radiator intercooler system to mount the BOV. i was thinking about going in the side of the intercooler but I havent measured anything yet to see if I would have enough hood clearance.
If someone who has done this has some pics or any feedback, I surely would appreciate it!
Old 01-13-2014, 03:15 AM
qwiketz
qwiketz's Avatar
I'm not much of an expert, but I have heard from the guys that know more than me that you want to mount it on the outside of a curve in your pipeing. With the red, it should not be as critical with you blower as with the bigger blowers. That thing flows a ton and it'll definitely reduce pressure on your intake tract.
Old 01-15-2014, 06:58 PM
dizwiz24
dizwiz24's Avatar
look up this on youtube:
dizwiz33
procharger idle
this is when i used to have the procharger intercooler and had a high quality paxton blowoff valve mounted to the side.
I have since removed the procharger intercooler (restrictive, reduces boost) and solely use meth/water inj.
I might add another less restrictive intercooler someday, in front of the radiator...esp since i removed a/c condenser
Old 01-15-2014, 07:16 PM
smooth1990
smooth1990's Avatar
dizwiz33
procharger idle
Thanks Diz,
How did that sound on your car mounted like that? was it loud?
Also I noticed you modified your air intake tube and have it down by passenger tire? It doesnt appear you have a filter on it? What exactly did you do there? I dont like the small k&n on my set up nor do I like that it doesnt get much fresh air down by the rad overflow.
Old 01-16-2014, 07:58 AM
dizwiz24
dizwiz24's Avatar
Thanks Diz,
Yes there is def an air filter on it. It isnt very big. I clean it often.
The filter is a custom k&n mounted to the face of the blower.that black plastic bucket is covering it up.
I also put chicken wire over the air intake scoop because leaves were going up the tube and quickly clogging the filter
Blow off valve was loud.
To BOV on procharger p600b?
Quick Reply: BOV on procharger p600b?
