Remote mount Turbo Oil supply?
I am in the process of installing my remote mount turbo setup on my 94 Corvette and i can not figure out where I am supposed to plumb my oil lines to get pressurized oil. Mine has an oil temp sensor screwed in the same exact location that I thought I was supposed to run my line. There is a square socket bolt right above the filter. Is that where i should be tapping into or should I be looking at the bolt above the sensor? What did you guys do for your supercharger or turbo LT1 builds to supply oil. Please show me pictures and explain how you did it.
It's confusing because this is the diagram I got from searching around showed right where I have a oil temp sensor pluged in
I have my T fitting in now all I need to do is wire my scavenge pump, plumb my oil return into the valve cover, wire some gauges, finish my cold side and she is ready to tune.
