Pics of Meth Kit install
Trying to figure out where to install my meth kit - can some of you post pics to give me a better idea? I have a LT1 engine bay with a Vortech and its pretty tight already!
Cruising
I have always wondered why the windshield washer fluid reservoir can't be used as a jug for a meth kit.... I haven't noticed but is there a dummy light for the low washer fluid
I use the WW res for mine. I have the pump and controller on top of the radiator shroud. It would be nice if it had a WW low fluid dummy light but I just check it periodically. IT doesn't go through all that much and that is with 17 gph of nozzles and me flooring it all the time.
Cruising
Current engine bay pic. I think im gona use the windshield wiper reservoir too.
I have my coolant reservoir from my 3rdgen sitting here but i havn't a clue where I could fit it in the vette. Thanks though! its dirty from the supercharger install.
Here is mine. I buttoned it up today for anticipation of the dyno coming up soon. I am running a AEM progressive controller mounted in the center counsel.
Hi Guys ! If you go to my website (BlowerWorks.net) then to the 'Downloads' section you'll find my GEN IV IG for 1985-89 and 1990-96 Vettes.
Great pics for much including the WW reservoir. The problem with using the WW reservoir is slosh and air when reservoir is less than say 1/2 full. The G forces move the liquid away from the PickUp. Bladder is best way or remote tank as many here have done.
Hope this helps - greg
