Yes or no?
You should lean it out to about 12.5 to 12.8 on Nitrous. Set your timing at 25 degrees and start leaning it a bit at a time to get there . Then you can try bumping the timing up 1 degree at a time to see the mph results.
The burn ring on the porcelain is too tall indicating too rich. It should be about 2mm tall for ideal jetting.
Here is some good info . Check out the 10th picture to see what I mean
http://honda-tech.com/forced-inducti...ug***-3063102/
