Cleaning throttle body
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Thank you for that post... I was about to instruct on how to clean a MAF I guess I need to learn how to read
Here's another instructional link
http://www.dvcorvettes.com/clean_air_passage.htm
Don't take off the Throttle Postion Sensor [TBS] unless you know how to put it back on.
Originally Posted by Perfusion
I see he drives a 95 - I know that on the 96s, the TPS is self-adjusting... Is that the case for the 95s as well, or will he need a multimeter?
If I need it I have a good meter that I use in troubleshooting the digital control systems on my injection molding machines. How do i tell if my TPS is self adjusting?
1 Post
Yours should be self adjusting. Each of the bolt holes that attach the TPS to the throttle body should be perfectly (or close) round. The adjustable TPS will have slotted bolt holes to allow movement.
