R134 conversion
St. Jude Donor '05-'06
I had thought about having mine changed over to R134A this Summer. I talked to my mechanic about it, and he told me if the system wasn't originally designed for R134A, that it wouldn't get as cold as an R12 unit. Mine didn't need anything, but to be recharged. 1 can of R12, plus labor $212, a little less than the $275-$300 they wanted for the conversion.
The choice is yours, but I like the coldness of the R12.
Location: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
1 Post
I had my system converted to R-134 back in '98 when my ac compressor seized. It's blows nice and cold. It seems to work better than the ac in my wifes Contour SVT.
Originally Posted by 89sleeper
Very expensive and hard to find it is also hard on the ozone layer(thats why they ouit making it!)
I thought they quite making it because the patent Dupont had expired and the Government throw them a bone and let tem make 134A (which by the way is also alegedly bad for the ozone).
134A is 14 bucks a can isn't it? Hard to believe that R12 is less. Either way, I saw an upgrade kit on Eckler's that comes with a compressor a receiver dryer and O-rings and it's $400. They're proud of their hoses too. Problem is, is that I don't know what all is wrong with the system since it hasn't worked since I've owned the car. I might just get whatever O-rings are required and fill it up with 134A and see what happens.
I just converted my wife's 91 Formula over to 134A. The 134 costs $7/can at wallyworld.
If you'd like I can send or post the proceedure I used and the place where I got the parts.
Originally Posted by 88redvert
Why convert.... R-12 is colder and still available....
