Help, where is the Auxiliary Fuse Block on a 1990
Have a Haynes Repair Manual, it is not very detailedl
1. Power locks do not work.
2. Circuit breaker #20 (30 Amps) provides battery to power seats and power locks.
3. Power seats work, power locks don't.
4. I can jumper battery to orange lead in the door lock switch and both locks will work.
5. My book does not show the Auxiliary Fuse Block.
6. Where is the Aux. Fuse Block and how do you get to it ?
St. Jude Donor '05-'06
You have to be a contortionist to get to it but if you remove the passenger side hush panel under the glovebox and reach way up in there behind the glovebox you'll find it.
And yes, one is for the power door locks. Others there are Horns/theft, secondary fuel pump, and Crank fuse for S.I.R.
The General should be shot for this one!
Cigarette lighter fuse 92 Corvette
My cigarette lighter quick working. I took off a panel under the dash on passenger side. I did not see any fuses. Am I suppose to take off the carpeted area or below that? Also, having trouble removing lock nut from rims. Can't find my key
