ZZ383/425 Crate Engine
Has anyone installed this ZZ383 in their C4 with TPI? How has it worked for you? This just may be my next move to upgrade my L98.
Thanks for your input.
Yep, there's one right now down at a shop I do some work at occasionally. It has the ZZ383 with the TPI and a Vortech supercharger. When we were doing the initial tuning we left the supercharger off the car, I was really impressed with how well it ran! It's a fast car without the supercharger, but when we hooked it up it was like
It's a good engine for the price, better than I expected!
Bump... I'd certainly hope most people or even redneck mechanics can build a 383 cheaper than the current price tag of that genuine GM motor. Looks like sometimes the heads alone are worth 50% of the entire package. Unless you can get the HT383 long block assy and put in your choice of really good flowing iron heads.
I know a lot of people that can build a 383 motor A LOT cheaper (and more powerful) than Lingenfelter can, but people buy them because they are well-built and warranteed. The GMPP engine is the same idea, it's not as exotic that's for sure, but it's well built and carries a very respectable warranty.
Also, the ZZ383 provides a solid base to build sopme more power on top of. Getting a safe 460-480 FWHP would be very easy, or bolt on a supercharger like the one I've seen and you have a VERY fast ride!
Received 3,043 Likes
St. Jude Donor '05
Another vote for the GM piece. How many rebuilds do you see that get driven hard for 150k miles and hold up? Quality has its price.
Does anyone have the power/torque numbers for the GM ZZ383 vs. the popular Lingenfelter 383 setup (219 Cam, Superram intake, etc)? *Any clue what heads are used with the Lingenfelter engine?
I've been planning on copying the Lingenfelter 383 using AFR 195 heads, but now I'm wondering if the standard ZZ383 will match or beat the performance. If so, I'd rather spend the extra cash and opt for the GM warranty.
St. Jude Donor '05
Lingenfelters older strokers used either ported 113's or the old 492 "turbo" head (the vortec will outflow it stick for stock). I imagine a 195 AFR would set your car on fire!
Originally Posted by Zix
but it turns out that the engine gets shipped with a weighted
front balancer, and we bolted on a stock Corvette zero-balanced
balancer which threw everything off. Put the correct balancer on and
it was great...
it was great...
installed the Corvette damper to avoid having to modify the
cross-member. If I am right about the ZZ383 being larger, how much
did you have to rework the frame for clearance?
BTW - the ZZ383 has a number of parts like the PM rods that aren't
commonly used by other builders. Local dealers are sometimes willing
to sell GM crate engines for a significant discount under retail. Include
me in the camp that feels these are a lot of bang for the buck.
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
For those of you with experience with this package, what injectors, intake, etc. are you having success with?
Originally Posted by Slalom4me
Does the ZZ383 have an 8" damper? I am guessing you initially
