MOMO RACE Wheel
MOMO RACE Wheel
Since it is a decent day here in Michigan, I found the time this morning to install the MOMO RACE wheel. The tele/tilt was a bear! It took me an hour to figure out how to get it to work I called the hub some very bad things, but in the end, I figured it out.
Link to CarDomain StalkerVette Page
Thanks guys
I took her around the block to see what the new wheel feels like. Dayum! I like it! There is no way I could go back to the factory wheel...
Now I'm thinking about getting one for my Lightning project truck.
Originally Posted by onetrackmind
That looks great, how about a list of needed part #'s to do the same?
This link will show you the correct adapter -- it will run you around $75.00.
I bought the wheel puller from Summit racing for ~ $12.00.
http://www.shopmomo.com/2702.html
I just bought a new wheel yesterday from a momo dealer, its a yellow/black commando wheel and the telescopic adapter, any tips I should know of before installing it, seems to be a easy job, but who knows....
Later today I'll do an overview for you.
Cheers
I didn't know anything about a wheel puller. I went to remove my wheel and thought it was just held in by bolts, but not sure how this thing comes off, I notice 2 screw holes in there, is this removed the same way the power steering pulley is removed ? Hope an autozone carries this tool..
I removed my wheel--got a wheel puller kit from autozone---But I HAVE NO IDEA how install the new one, I thought this was going to be a simple bolt in piece, I understood how to put those screws in the wheel hub and use the bigger bolt to pull off the wheel--but putting it back on is going to be confusing?? Anyone, I have the momo adapter and the momo commander wheel--trying to install this momo adapter
Originally Posted by STREETKNIGHT
Man, thats sweet Need to replace mine. Maybe I'll look into that set up. What kind of shifter is that?
The shifter is a Hurst V-Matic 2. It took a ton of mods to get it to fit!
I put a MOMO on my '82 but it eliminated my telescopic part. I still have the tilt but I miss the telescopic feature. I guess they don't make an adapter for the C3's.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I think an installation tip is on C4 Guru. If not, I can send you a copy via email on Monday, if you like.
Larry
code5coupe
