Bose speaker amp fuses
Old 05-16-2006, 12:31 AM
dhall
Cruising
dhall's Avatar
Default Bose speaker amp fuses
Is there a fuse for the Bose speaker amps located anywhere beside the fuse box on the right side of the glove box on a 1990 convertible? Thanks.
Old 05-16-2006, 12:33 AM
Demonic85
Demonic85's Avatar
No, the Bose system uses amplifier cards located near each speaker. If you have the later version (Bose Gold?) You can fix the amps yourself. Theres a guide on how to do this in the C4 Tech Section.
Old 05-16-2006, 01:19 AM
bogus
bogus's Avatar
there is a relay, tho... I think it's under the steering column.
Old 05-16-2006, 01:38 AM
Demonic85
Demonic85's Avatar
Thats correct, on '90 and '91's its located under the steering column on the left side.
To Bose speaker amp fuses
Quick Reply: Bose speaker amp fuses
