Vert Tops - cloth vrs vinyl
This winter's project is going to be replacing the top on my 'vert. I'm 99% likely to go to a cloth top (vinyl now) but figured I'd see if there is any reason (aside from cost) to consider vinyl instead.
Thoughts?
Thoughts?
I made that same choice (cloth) last winter based on look more than anything. I understand the vinal and cloth tops will last about the same amount of time, but the cloth will look better toward the end.
Vinyl tends to shrink with age. This can cause fitment problems. Canvas will not shrink, so your top will open and close years later as well as it does when the top is brand new. Canvas also won't hold wrinkles if you leave the top stowed for extended periods of time (I've left mine down for months many times). I recommend canvas.
Be well,
SJW
Be well,
SJW
Be well,
SJW
Be well,
SJW
All good points thanks - look slike my initial plan of cloth was the right one.
Sad part is I've found a great price on a cloth tan top for an '88 (no easy feat) but the weather strip is going to cost more than the top itself
Ah well, what else is there to do over the long cold Wisconsin Winter hey?
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
My GS had vinyl and was a PITA to keep clean. The red car had cloth and was very easy to clean as long as you kept it protected.
My vote, cloth.
My vote, cloth.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Oh, btw, I like the canvas, too, but I've only driven vinyls. And they are just ok.
Originally Posted by LT4CompYell
When does it start getting really cold in your area? And when do you consider it ended?
I lived in Nashville for 8 years (miss that weather) and when I first moved here I was shivering by October, but eventually I fattened up and now its no problem.
CLOTH! and tan would look awesome on your car. When my black cloth wears out, I plan on replacing it with a cloth tan/saddle top. Ever seen a C5 electron-blue with a saddle-colored top? It's beautiful?
yeah, its got a tan (saddle) vinyl right now and saddle intereior, so sticking with tan/saddle. Though white with a GS stripe is really tempting but that means a whole new interior too - way too much $
another top question
I have a tan cloth top..it is original and now after 11 years its time to replace it..one question..the inside of the top is black, is this two pieces one outside and one inside?
