Will C5 Z06 wheels fit a C4?
yes a friend of mine who owns a c5 had a set with road race slicks on them...he let me use them the last time we had an autocross...they fit fine with no rubbing...i'll see if i can dig up the pics of them mounted on the car
They will fit just fine. I have Z06 wheels on my '96 convertible. If you are getting new tires, it is better to get the same tire diameter from front to back, like the stock C4. Stock Z06 tires are an inch smaller diameter in front than in back. However, I have the inch diameter difference on mine (came off my C5) and haven't seen any problems. It would just be better for the traction control and active handling if the tire diameters were correct.
I put 285s on the front of mine, works great. I just bought another set, so now I'll be running OEM Z06 17s all the way around. The 18s jacked up the rear a half inch.
St. Jude Donor '08-'09
Originally Posted by VetNutJim
YES!
And they look GREAT too.
They will also fit Camaro's. Uh-oh... is it ok to say 'that' word here?
I knew a guy with a black SS w/gold Heritage paing job on it with the Z06 wheels It looked SHARP!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
a couple of Q's...
...will the 18" diameter throw the speedo calibration off??
If you have C4/ J55 brakes will they still fit?
What tire size did they use? I use 275/40/17 up front and 315/35/17 out back.
Tom
Tom
St. Jude '03-'04-'05-'06-'07
Originally Posted by vancityguy
they will fit 88+ c4's perfectly but 84-87 would require adapters
C5 & C6 Z06 wheels will fit... I've got both, C5 for the street & C6 for auto-x tires. The 18" rears actually made my speedo closer to spot on that the orig. 17".
Are your C6 Z06 wheels OEM or aftermarket? If aftermarket, are they the exact same size and offset as OEM?
