switch on under hood lights
Old 10-24-2006, 12:40 PM
Gary R
Gary R's Avatar
Default switch on under hood lights
I have been thinking of putting a manual switch on my under hood lights. It would be pretty easy and it would allow me to keep my hood open for long periods of time without unplugging the lights. Has anyone else already done this? If so, what kind of switch did you use and where did you put it?
I think I'll put it on the passenger side about where the headlight bracket is. That seems to be the easiest and convienent spot.
Gary
Old 10-24-2006, 12:44 PM
Sam Lam
Sam Lam's Avatar
Gordon Killabrew sells such a kit for $20 with instructions and I just bought this kit. However, I have not had time to install it and it appears to be very simple. I think it could be done without a kit. Here is his web site if you are interested in the kit: http://www.gordonkillebrew.com/
Look at the "products" section.
PS: I highly recommend you place minimial info into your profile as this is a requirement to use this forum
Old 10-24-2006, 12:45 PM
RonVette2
RonVette2's Avatar
Here is a picture of one that I saw this morning that a friend and CF memeber put in his Vette:
Personally I just leave mine unplugged.
Old 10-24-2006, 12:49 PM
Laurel
Laurel's Avatar
You could just do the Laurel mod, buy a car that doesn't have working under hood lights.
Old 10-24-2006, 12:56 PM
Z51L83
Z51L83's Avatar
thats a pretty trick setup
i just unplugged mine for shows
Old 10-24-2006, 01:07 PM
Gary R
Gary R's Avatar
Thanks, for info and I'll try to update my profile.
Gary
Old 10-24-2006, 01:17 PM
Jerris
Jerris's Avatar
You can always just unplug the fuse that is in the fuse holder next to the vac canister. Leave the fuse inside the holder so that you can plug it back in if you want the lights to work.
Old 10-24-2006, 01:20 PM
Fuzzy Dice
Fuzzy Dice's Avatar
Cruise-In IV Veteran
that's how mine have been for 4 years now but I kep the fuse in the center console...
Old 10-24-2006, 01:39 PM
GSjimbo
GSjimbo's Avatar
That's what I did.
Old 10-24-2006, 01:50 PM
Gary R
Gary R's Avatar
Jerris, I like your idea. I didn't even know there was a fuse there. Mine was attached to the LH side marker light. I don't like to cut into factory wiring if I don't need to. Gary
Old 10-24-2006, 01:57 PM
Gary R
Gary R's Avatar
Sam, I must admit stupidity about your suggestion to change my profile. What are the requirements and where do you post it? Gary
Old 10-24-2006, 02:03 PM
Eakster
Eakster's Avatar
You can keep the fuse in its holder- just move it over one slot - this is how the previous owner was driving around in mine. It's not as visible as a groovy switch tho..
Old 10-24-2006, 02:58 PM
Bad Karma
Bad Karma's Avatar
I thought that was how I bought mine, until I was going through the car an found out the pevious owner had simply unplugged them.
Old 10-24-2006, 03:00 PM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Two Radio Shack rocker switches, one on each side took care of it on my C4.
Larry
code5coupe
Old 10-24-2006, 03:10 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I mounted mine next to the lights.
Just had to drill two holes.
Oops, SORRY! I know how much that word makes some of you
Old 10-24-2006, 03:13 PM
vinnies87
vinnies87's Avatar
Larry
code5coupe
Right you are, goes right on the lines, Home depot 1.99 ea... $4.00 total for on/off hood lights
Old 10-24-2006, 03:50 PM
94ZR1
94ZR1's Avatar
St. Jude Donor '06
I was going to put switches on it but the plugs are just too easy to just unplug the once or twice a year the hood will stay up over an hour or so
Old 10-24-2006, 07:06 PM
Steel Blue 91
Steel Blue 91's Avatar
That's the answer. Just leave the fuse in the glove box (or console) for use if required.
To switch on under hood lights
Quick Reply: switch on under hood lights
