LCD display Not working!!!!!!!!!
Old 01-10-2007, 01:11 AM
stevenj109
Navigator
stevenj109's Avatar
Default LCD display Not working!!!!!!!!!
i Have A 1990 Corvette And The LCD Displays Not Showing Any Data..............Everything Elses Works But Its Not Showing The MPH,Gas......thing Like That..I Need Halp PLZ Ant And All Info On this Would Be Great Ill Bee Off Line For The Rest OIf The Night....Plz Send An E-Mail Or Something lcd549@yahoo.com
Old 01-10-2007, 01:51 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes sir, will do.
Old 01-10-2007, 05:17 PM
stevenj109
Navigator
stevenj109's Avatar
Default Not Fair :(
50 looked at this and only 1 answered and its not even the answer im looking 4 Comon PPL This Is Realy A Prob. For My Car I Cant Tell How Fast Im Going And For That Matter I cant Tell If The tank Is Full Or Not.Like I said The Back Light Lights Up But No Data On The Display.......................why?
Old 01-10-2007, 05:22 PM
jhammons01
jhammons01's Avatar
Central Coaster said he would send you an email per your request.
Old 01-10-2007, 07:29 PM
jonecap
jonecap's Avatar
Slap the dash...it'll work
Old 01-10-2007, 07:45 PM
stevenj109
Navigator
stevenj109's Avatar
Default Ok
Tryed It.............Slaped The HELL Out Of It And Nothing, Even Did It While The Car Was Running And While It Was Off............Any Other Ideas?
Old 01-10-2007, 07:47 PM
evmlarry
evmlarry's Avatar
Did the 90 still have the full LCD dash, or is this the first year they went to that updated dash?
Old 01-10-2007, 08:11 PM
stevenj109
Navigator
stevenj109's Avatar
Full Dash And Im not shure On The Other Part........I Think It was Standard Equiped
Old 01-10-2007, 09:58 PM
89er
89er's Avatar
On my '89 I once lost the miles per gallon instant/average and the range/trip counter. It turned out to be a bad ECM. I think it was broken by removing and connecting the positive terminal of the battery cable to disconnect power instead of the negative one. After being careful with connecting the battery I have not had another failure.
Old 01-10-2007, 10:15 PM
RWD_tech
RWD_tech's Avatar
pull out your mulitmeter buddy and look at the wiring diagram. it could be many things. if you are incapable of that you need to take it to a shop
Old 01-10-2007, 10:19 PM
Bad Karma
Bad Karma's Avatar
Could be a no signal getting to the dash or the lcd itself. You may have to send out the unit for repair.
Try pulling the wiring diagrams and seeing if the leads to the LCD as sending anything.
Old 01-10-2007, 11:34 PM
stevenj109
Navigator
stevenj109's Avatar
Default Thank You Thank You Thank You Thank You
89er You Are The Best THANK YOU SOOOOOOOOOOOOOOOOOOOOOOOOO MUCH FOR THE HELP, It Works How Ever It Flicker On And Off Ill See About Replacing That Part...................THANK YOU AGANE, Stevenj109
Old 01-11-2007, 05:09 AM
Fastmax32168
Fastmax32168's Avatar
Can you see the display when the car is turned off? If so then you dash is what is called sunburnt and the liquid crystal displays need replaced.
Old 01-11-2007, 09:11 AM
Goldcylon
Goldcylon's Avatar
Its the updated dash also called the Hybrid dash. 89 was the last year for the Star Wars Atari style dash. At least thats how my 90 looks. Any chance a fuse could be involved here?
To LCD display Not working!!!!!!!!!
Quick Reply: LCD display Not working!!!!!!!!!
