6-way power seat switch removal problems - CorvetteForum - Chevrolet Corvette Forum Discussion
C4 General Discussion
General C4 Corvette Discussion not covered in Tech
Old 05-14-2007, 12:58 PM   #1
Vette Gator
CF Senior Member
Vette Gator's Avatar
Default 6-way power seat switch removal problems
This weekend's project was to try to get the 6-way seats on my 89 vert working. I was partially successful. In spite of my initial diagnosis, a known good seat track had the same problems, so I know it's in the switches (the wires were checked and they are all OK). I took the switch assembly out of the console and it seemed like there were three switch modules plugged into a rubber holder that had the wiring attached. The end paddle switches are both stuck into this rubber holder by one post each, and no matter what I tried, I could not get them out. It looked like once I got the end ones out, the middle joystick switch would come out as well. Does anyone know the trick? With the high cost of replacement switches, I would really like to try re-building mine first.
Since I couldn't get the switches out to clean and re-condition the contacts, I sprayed TV contact cleaner inside, worked the switches, then sprayed in compressed air. Repeated a couple of more times. This got the front-back control working, which was the most important goal (according to my 5'10" wife; her 6'3" husband doesn't see the need to move the seat forward ).
Vette Gator is offline   Reply With Quote
Old 05-15-2007, 11:09 AM   #2
ejscarfo
CF Senior Member
ejscarfo's Avatar
You might be better off searching the used Vette parts vendors for a used switch. I picked up left and right switches from eBay for $50 to install into my 85 so I can have driver and passenger power seats. I've seen used switches all the time for under $40.
ejscarfo is offline   Reply With Quote
Old 11-05-2013, 02:40 PM   #3
Kettsvette
Junior Member
Default TV Tuner Cleaner for switches
You, sir, are a genius!!! I had exactly the same problem with the forward and reverse seat switch and was not looking forward to spending the time to remove half the interior just to get at the seat switch. I tried your solution of spraying the TV Tuner Cleaner into the switch without removing it and, whalla, the seat switch worked.
Thanks for the solution to my problem.
Kettsvette is offline   Reply With Quote
Old 11-05-2013, 03:49 PM   #4
ddan
Junior Member
I'm having a similar problem, sort of... I can only move the driver set around and the lumbar supports only work on the passenger seat. Will try the TV tuner and see if that fixes both switches, or it's tear down time to try and repair...
ddan is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 6-way power seat switch removal problems
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    bypassing wiper switch LongRoadHome C3 General 11 06-29-2016 06:23 PM
    Warning Light Wiring Questions in a 73 Crafty12 C3 Tech/Performance 15 10-09-2012 10:12 AM
    Clutch pedal pivot bushing replacement from underneath ProjectC4 C4 Tech/Performance 0 03-25-2012 02:54 PM
    just repaired ignition switch...Pass key fault/ VATS repair dhirocz C5 Tech 1 11-19-2009 10:35 PM
    C1 Parking Brake Flasher VetteJohn C1 & C2 Corvettes 0 06-27-2006 10:15 AM
    Tags
    1985, 2004, 84, awd, c4, c5, corvette, power, removal, replace, replacing, saturn, seat, switch, vue
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
